High and Unstable Latency On LAN??
ztaylor9632
I have a LAN made up of 2911 ->3750->2960->2960->2960->2960
Pings from a computer connected to the last switch in the chain are ranging anywhere from 9-15ms with spikes up to in the 100's. Pinging internally from the switch to the router is 16/8/25, 6/15/20.
From my understanding these should all be 1ms pings.
Spanning tree portfast is enabled on all of the ports.  I have fiber connecting all of the switches together. I have looked for level 1 problems already and did not find any.
Just wondering if anyone had any ideas?
Thanks.
paolo bevilacqua
I don't know what you're pinging and from where exactly, but if you are pinging to routers or switches, then ping times are not indicative of anything.
If you want to do a true network test, use two PCs with appropriate software.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As already noted by Paolo, ordinary pings can be inaccurate.  Their principal purpose is to determine if there's reachability.  As he also described, performance testing software is what you really need for accurate latency measurement.  BTW, many of the later Cisco devices support special SLA testing which will also provide much more accurate information about performance.
That noted, highly variable ping times, as you note, may be indicative of transient congestion.  What you might also do, for every network device port along the path, check for interface drops (which often go hand-in-hand with congestion).
