ASA OSPF Reference Bandwidth
Luke Robertson
I'm looking at an ASA, which has a default reference bandwidth of 100Mbps. This will form a neighbour relationship with Nexus switches which have a default reference of 40Gbps.
The links in the DC vary between 1Gbps, 10Gbps and 40Gbps. I would like the reference bandwidth to be 100Gbps, so all the interface speeds get an appropriate cost (not all just set to 1).
I have found a lot of information on how to change the reference bandwidth on IOS, and I can see that it's the same on NXOS, but I can't find how to change it on the ASA.
Can anyone tell me how this is done?
Reza Sharifi
Apparently the ASA by default figures out the cost based on the bandwidth and so you don't have to configure reference-bandwidth.
From the config guide:
The ASA calculates the cost of an interface based on link bandwidth rather than the number of hops to the destination.
Link;
http://www.cisco.com/c/en/us/td/docs/security/asa/asa90/configuration/guide/asa_90_cli_config/route_ospf.html
I did see that, but I think that is to compare OSPF's cost-based metric to RIP's hop based metric.
Running 'show ospf | inc bandwidth' shows that the 'Reference bandwidth unit is 100 mbps' which suggests that it is still used.
