ASA - routing + NAT problems. It used to work
There is an ASA 5505 8.2(5). I've been working with. There are two vlans (172.21.1.0/24 and 172.21.2.0/24),  one port for each, both connected to a switch, which has been configured with the same two VLANs. No trunk ports. ASA denys packets due to Asymetrical translations; same inter and same intra interface routing set.
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
nat (VoIP_PH) 0 access-list VoIP_PH_nat0_outbound
nat (VoIP_PH) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
global (Telecom) 1 interface
Of course, inside_nat0_outbound is an access list that reads, among other lines, 172.21.1.0/24 --> 172.21.2.0/24, and  VoIP_PH_nat0_outbound reads 172.21.2.0/24 --> 172.21.1.0/24.
My log screen is flooded with Asymetric translations messages and the router does not route traffic between both subnets.
Any ideas?
Thanks.
Regards.
chris noon
Can you post the error message you are receiving?
Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src inside:172.21.1.46/25128 dst inside:172.16.15.10/53 denied due to NAT reverse path failure
                         172.16.0.0/24
                        MPLS
                           .254
                           |       _______________
172.21.1.0/24 __|__.1|                            |
                                   |          ASA           |
                                   |______________|
have you already configured a NAT Exempt Rule between both private Networks?
