04-14-2010 09:11 AM - edited 03-06-2019 10:37 AM
Guys,
My ASA 5510 has the ASDM which I can download and install or view through the browser, however when I try to either I can only get so far as putting in the credentials then both forms stop. The browser just stays a main page will open and the app just closes.
I have built another fresh PC windows xp just incase my was corrupt, however I still get the same thing. the ASA is running 7.0(8) and the ASDM is 5.0(8).
Any ideas, I can still telnet to the device but I can't seem to open the ASDM and the problem seems to be the device.
Solved! Go to Solution.
04-14-2010 12:42 PM
Guys,
I have to say "Sorry" to you all.
@Ryan, you did a good job in this thread.
@Jon , Long time no see. You're still around. Nice to know that you have been helping people as always. You rock!!
Toshi
04-14-2010 12:23 PM
thotsaphon wrote:
Well,
I'm not sure why I got low rating on this thread. If it was my wording,"restart the device", then I would have to tell you that I and my colleagues had to do this as a last resource for this kind of problem when not accessing to ASA for a long time. It worked for us and the point is we did try many different java versions and many different machines as well.
Wow, this is my first day to get back to work with Netpro again. It's not a good day though.
Toshi
Toshi
Agreed, not sure why your answer got a 1. +5 to try and balance it out.
Jon
04-15-2010 01:28 AM
Guys,
I've tried on another clean PC just to be sure and the versions I'm running are:
Java 1.6.0_19
ASDM 5.0(8)
ASA 7.0(8)
Browser 6.0
XP 5.1
I've rebooted the ASA device but this does not make any difference. It's just really odd, if there was an error messege or something that I could diagnose it would not be a problem.
04-15-2010 04:35 AM
Try java version 6 update 7:
04-15-2010 05:10 AM
That worked, Ace. Thank you.
