ASP - Remote Function - Error: Failed to execute trigger
Sven Hruza
Level 8
Level 8
I tried to get my macros running by a remote server.
This is my remote function file named "remote_test_pc.asp":
    if [[ $LINKUP -eq YES ]]; then
        conf t
            interface  $INTERFACE
                macro description $TRIGGER
                description PC-VoIP-Port
                switchport access vlan $ACCESS_VLAN
                switchport mode access
                switchport voice vlan $VOICE_VLAN
                storm-control broadcast level pps 1k
                storm-control multicast level pps 2k
                storm-control action trap
                no logging event link-status
                srr-queue bandwidth share 10 10 5 75
                srr-queue bandwidth shape 10 0 0 0
                priority-queue out
                mls qos trust dscp
                no snmp trap link-status
                spanning-tree portfast
                spanning-tree bpduguard enable
                service-policy input PO_TRUST-PHONE
            exit
        end
    fi
    if [[ $LINKUP -eq NO ]]; then
        conf t
                no macro description
                description DEFAULT-CONFIG
                switchport access vlan 999
                no switchport voice vlan $VOICE_VLAN
                priority-queue out
                mls qos trust dscp
                no service-policy input PO_TRUST-PHONE
                fi
            exit
        end
    fi
And this is my config on the switch for mac-group and macro:
macro auto mac-address-group Test-PC
mac-address list 0019.9990.5509
macro auto global processing
macro auto global control detection mac-address
macro auto execute Test-PC remote ftp://192.168.1.11/remote_test_pc.asp ACCESS_VLAN=123 VOICE_VLAN=127
When I plug this workstation to the following syslog messages:
Switch#
Loading remote_test_pc.asp !
[OK - 1702/4096 bytes]
Enter configuration commands, one per line.  End with CNTL/Z.
Switch con0 is now available
Press RETURN to get started.
Error: Failed to execute trigger Test-PC, please verify trigger exists and maps to valid function
Sep 26 11:45:37.755: %SYS-5-CONFIG_I: Configured from console by console
Sep 26 11:45:37.772: %AUTOSMARTPORT-5-INSERT: Message from tty0(user id: 😞 Device with mac-address 0019.9990.5509 detected on interface FastEthernet0/3, executed Test-PC
Switch#
The port is working as it should, but I am wondering about the error message.
Switch is 2960 with IOS 12.2(58)SE2.
Can anybody explain what that means?
Thanks a lot!
Sven
ankugarg
Level 7
Level 7
Hi Sven,
I believe you won't be getting this message consistently...Ignore this for now...This won't have any functional impact...This was taken care in 15.0(1)SE.
-Ankur
ankugarg
Level 7
Level 7
Hi Sven,
-Ankur
Hi Ankur,
I did a lot of tests (> 20 times of link up/down) and evertime I get that error message.
But okay, if it is not important I will ignore it .
Later I will do some tests with 15.0(1)SE.
Thanks!
Sven
