ASR 920 will not take startup-config
NerpX30
Here is the boot output:
UEA platform with 3670016 Kbytes of main memory
Warning: filesystem is not clean   <-------#People say this is an error from a dirty reboot#
Located asr920-universalk9_npe.16.09.07.SPA.bin <-----------------Correct iOS
Image size 447088417 inode num 15, bks cnt 109153 blk size 8*512
Boot image size = 447088417 (0x1aa60721) bytes
pid_str[ASR-920-4SZ-A]
ROM:RSA Self Test hash Mismatch in long long word No. 0
ROM:Sha512 Self Test
Package header rev 2 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
calculated 47ccb06d:d3c5cb0f:538f05d7:b3fbc2ad:72f44590
expected 47ccb06d:d3c5cb0f:538f05d7:b3fbc2ad:72f44590
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Passing control to the main image..
Stage2 Bootldr for Polaris-image
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Fuji], ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 16.9.7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Wed 10-Feb-21 07:28 by mcpre
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
cisco ASR-920-4SZ-A (Freescale P2020) processor (revision 1.0 GHz) with 896449K/6147K bytes of memory.
Processor board ID FOC2626R128
2 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1231647K bytes of eMMC flash at bootflash:.
Press RETURN to get started!
*Oct 28 06:10:18.838: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*Oct 28 06:10:19.753: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = ASR-920-4SZ-A Next reboot level = metroaccess and License = metroaccess
*Oct 28 06:10:33.142: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initializedAllocate serdes lanes for 0/0
*Oct 28 06:10:39.726: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
*Oct 28 06:10:40.628: [IOX DEBUG] IOx subsystem is inlcuded but it is marked as not needed
*Oct 28 06:10:40.719: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Oct 28 06:10:40.727: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Oct 28 06:10:40.728: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Oct 28 06:10:40.731: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL GigabitEthernet0: Physical Port Link Down
*Oct 28 06:10:41.658: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Oct 28 06:10:41.662: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Oct 28 06:10:41.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Oct 28 06:10:41.664: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Oct 28 06:10:42.422: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Oct 28 06:10:44.070: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setting.
*Oct 28 06:10:44.203: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Oct 28 06:10:44.510: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Oct 28 06:10:44.580: %SPA_OIR-6-OFFLINECARD: SPA (2xGE-4x10GE-FIXED) offline in subslot 0/0
*Oct 28 06:10:44.616: %IOSXE_RP_ALARM-2-PEM: asserted CRITICAL Power Supply Module 1: Power Supply Failure
*Oct 28 06:10:45.014: %SYS-5-RESTART: System restarted --
*Oct 28 06:10:47.638: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Oct 28 06:10:47.638: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Oct 28 06:10:47.649: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Oct 28 06:10:47.649: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Oct 28 06:10:47.801: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0Allocate serdes lanes for 0/0
*Oct 28 06:10:52.159: %IOSXE_RP_ALARM-6-INFO: asserted MAJOR FIXED IM subslot 0/0: Boot state
*Oct 28 06:10:53.224: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Oct 28 06:10:53.225: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
Authentication passed
*Oct 28 06:11:00.218: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
*Oct 28 06:11:11.746: %SPA_OIR-6-ONLINECARD: SPA (2xGE-4x10GE-FIXED) online in subslot 0/0
*Oct 28 06:11:11.947: %IOSXE_RP_ALARM-6-INFO: cleared MAJOR FIXED IM subslot 0/0: Boot state
*Oct 28 06:11:11.948: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL xcvr container 0/0/2: Transceiver Missing - Link Down
*Oct 28 06:11:11.949: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL xcvr container 0/0/3: Transceiver Missing - Link Down
*Oct 28 06:11:11.949: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL xcvr container 0/0/4: Transceiver Missing - Link Down
*Oct 28 06:11:11.949: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL xcvr container 0/0/5: Transceiver Missing - Link Down
*Oct 28 06:11:11.950: %IOSXE_RP_ALARM-6-INFO: asserted INFO GigabitEthernet0/0/0: Physical Port Administrative State Down
*Oct 28 06:11:11.950: %IOSXE_RP_ALARM-6-INFO: asserted INFO GigabitEthernet0/0/1: Physical Port Administrative State Down
*Oct 28 06:11:13.578: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Oct 28 06:11:13.578: %IOSXE_RP_ALARM-6-INFO: cleared INFO GigabitEthernet0/0/0: Physical Port Administrative State Down
*Oct 28 06:11:13.579: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL GigabitEthernet0/0/0: Physical Port Link Down
*Oct 28 06:11:13.648: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Oct 28 06:11:13.649: %IOSXE_RP_ALARM-6-INFO: cleared INFO GigabitEthernet0/0/1: Physical Port Administrative State Down
*Oct 28 06:11:13.649: %IOSXE_RP_ALARM-6-INFO: asserted CRITICAL GigabitEthernet0/0/1: Physical Port Link Down
*Oct 28 06:11:13.681: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/0/2, changed state to down
*Oct 28 06:11:13.682: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/0/3, changed state to down
*Oct 28 06:11:13.688: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/0/4, changed state to down
*Oct 28 06:11:13.694: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/0/5, changed state to down
Router>
Router>
The startup-config is in the bootflash: memory. It sees it when it boots up, but it won't apply it. It was password lost, so i performed a password recovery from this
URL: https://www.cisco.com/c/en/us/td/docs/routers/asr920/b_Chassis_Guide_asr920/using-ztp.html#concept_kdv_g2c_1db
The Password Recovery section told me to execute this code:
  • Press Break on the terminal keyboard within 60 seconds of power up to put the router into ROMMON. In some cases Ctrl+Break key combination can be used.
  • Type confreg 0x2142 at the ROMMON.
    1> confreg 0x2142
    1>sync
    The router reboots, but ignores the saved configuration.
  • The router will reload and prompt for configuration.Type no after each setup question, or press Ctrl-C to skip the initial setup procedure.
  • Type enable at the Router> prompt.
    You are now in enable mode and should see the Router# prompt.
  • Reset the config-register from 0x2142 to 0x2102. To do so, type the following:
    config-register configuration_register_setting
    Where, configuration_register_setting is 0x2102. For example,
    (config)# config-register 0x2102
I'm extremely new to Cisco. Please help!
marce1000
      - Please echo verify the config register setting after you specify it,
 M.
Current output:
#show version
Smart Licensing Status: Smart Licensing is DISABLED
          >...The router reboots, but ignores the saved configuration.
 - Can you manually copy startup-config to running-config ?
 M.
can you post the output of:
sh bootvar
