ASR QoS Class based policy not working as expected
manugarg19
Hi All,
I configured an ASR with following QoS
Ip access-list ext AF4
permit ip 10.0.0.0 255.255.255.0 any
ip access-list extended 197
permit ip any host 20.0.0.2
class-map match-all AF4_include
match not access-group 197
class-map match-any AF4_output
match class-map AF4_include
match access-group name AF4
Policy-map child
class AF4_output
set dscp af41
class class-default
policy-map parent
class class-default
service-policy child
As per my understanding QoS should only match AF4 ACL entry and mark then with AF41
However All the packet including not in the ACL AF4 are classified and marked as AF41.
Any help to understand what has been done wrong ?
Thanks in advance for help !!
Rgds
MG
Hello @manugarg19 ,
>> all packets not matching ACL 197 are a match for class-map -- will there be further lookup for ACL AF4 ?
I was referring to the child class-map called AF4_include that is then invoked in class-map AF4_output that uses match-any that is a logical OR between (not matching ACL 197 ) OR ( matching ACL named AF4)
The further lookup for ACL AF4 is meaningful only for packets matching ACL 197 in that case AF4 ACL can decide the packet is a match if it sourced by subnet 10.0.0.0/24 .
Only one match is enough.
The final part does not change
Hope to help
Giuseppe
with match any all criteria must match at the same time.
Coming to your last post:
match not access-group 198
becomes
match not access-group 197 198
because a OR operator is used for similar match so packets not matching ACL 197 or not matching ACL 198 are a match for this class-map.
Giuseppe Larosa
Hello @manugarg19 ,
so class-map AF4_output will mark with DSCP AF41 all packets not matching ACL 197 or packets matching named ACL AF4.
Hope to help
Giuseppe
@Giuseppe Larosa
Thanks for your reply.
all packets not matching ACL 197 are a match for class-map -- will there be further lookup for ACL AF4 ? I am confused here, as to me seems like all packets are already matching class-map and thus dropping further lookup and reason I am seeing every outgoing packet marked with DSCP AF4.
Can you help me understand. How Class-map match-all will work with this configuration ?
ip access-list ext 198
permit tcp host 10.16.15.2 eq bgp any
permit tcp host 10.16.15.2 any eq bgp <<<<<<<<<<<< this is  configured WAN IP.
ip access ext 197
permit ip host 20.0.0.2 any <<<<<<<<<<<<<<<<<<<< its a device loopback IP.
ip access extended AF4
Rgds
Manu Garg
Hello @manugarg19 ,
Hope to help
Giuseppe
becomes
@Giuseppe Larosa  Thanks for describing it.
