assist me at Drag & Drop Question
Amr Ali
hello dears,
i am looking for a help , as i can't figure out why he chose Specifically 128 at ACL as any no. would work
" the question at the attachment "
cheers
kcnajaf
Level 7
Level 7
Hi Amr,
128 is correct choice here. This is because this is an extented access-list (since both source and destination address are used), and the range for extented access-list is from 100–199. Out if the given option only 128 will fit for an extented accesss-list.
Please see the range for ACL for your reference.
Access List Ranges
TypeRange
IP Standard1–99
IP Extended100–199
IP Standard Expanded Range1300–1999
IP Extended Expanded Range2000–2699
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
Hi Amr,
Access List Ranges
TypeRange
IP Standard1–99
IP Extended100–199
Hope that helps.
Najaf
Sandeep Sharma
Hi Amr
When you need to user port/ destination and source based filtering using ACL you need to use extended ACL.
Thanks & Regards
Sandeep
Amr Ali
thanks all of you
