auto upgrade path ... how to set them
Heiko.Bialozyt
on show boot-command i found an entry called "auto upgrade path". what stand it for?
Switch#sh boot
BOOT path-list      : flash:/ies-lanbase-mz.122-55.SE5/ies-lanbase-mz.122-55.SE5.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : yes
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
NVRAM/Config file
      buffer size:   65536
Timeout for Config
          Download:    0 seconds
Config Download
       via DHCP:       disabled (next boot: disabled)
i would like to bring a new IOS-image to this switch while auto-setup-procedure. Auto upgrade is already set to yes.
Does anybody know how to use this feature?
EEM does not work correct because it's limited by ies-lanbase-version of IOS.
thanks for good ideas
Heiko
0 Replies 0
