Avaya 9608 on Cisco 3650 being forced on Data VLAN
islanderzero
I took over for a network engineer who left and I'm trying to configure a Cisco 3650 with IOS-XE version 16.12 to work with some Avaya 9608Gs with Application File 7.1.6.0.8. There's a Cisco ISE server that allows it on the network using mab but doesn't push the VLAN to it. All IPs come from a windows DHCP server on VLAN 100 for Voice and VLAN 50 for Data.
I know my switch configuration is the problem because the phones are able to correctly get on the correct VLAN and subnet when I plug the phones on one of the other switches. I enabled LLDP on the switch using lldp run and when I do a show lldp entry [device], i get the below:
Switch#sh lldp entry AVX7F0000
Capability codes:
(R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
(W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Local Intf: Gi1/0/47
Chassis id: 10.10.252.250
Port id: c81f.ea0f.b300
Port Description - not advertised
System Name: AVX7F0000
System Description - not advertised
Time remaining: 115 seconds
System Capabilities: B,T
Enabled Capabilities: B
Management Addresses:
The above in bold with System Capabilities for Bridge and Telephone are available for the device but only Bridge is enabled under Enabled Capabilities. Anyone know what would cause that or how to force the switch to enable the device as a telephone? Could this be causing my IP issue? I really don't see any difference between my configuration and other configuration of the other switches.
Thank you
5 Replies 5
johnd2310
Level 8
Level 8
What is you switch port config. Was the other switch you tested the phone on a 3650 running 16.12?. This could be bug in 16.12
John
**Please rate posts you find helpful**
Hi John,
All the switches are running the same IOS-XE version, 16.12. Below is my port configuration.
interface GigabitEthernet1/0/40
 switchport access vlan 50
 switchport mode access
 switchport voice vlan 100
 authentication event fail action next-method
 authentication event server dead action authorize vlan 50
 authentication event server dead action authorize voice
 authentication event server alive action reinitialize
 authentication host-mode multi-domain
 authentication order dot1x mab
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 authentication violation restrict
 mab
 snmp trap mac-notification change added
 snmp trap mac-notification change removed
 dot1x pae authenticator
 spanning-tree portfast
 spanning-tree bpduguard enable
 spanning-tree guard root
Is it possible that this is an older Avaya phone that derives the voice VLAN from DHCP options when it issues a DHCP request in the untagged VLAN? I am not an Avaya expert, but I do recall some years back that this was how Avaya phones learned the tagged/voice VLAN.
Hi Elliot, unfortunately that is not the case as I specified above, the phones have no problem getting an IP address on any other switch on the network - just the one that I cnfigured.
Does it still fail to get on the voice VLAN if you temporarily turn off the 802.1x?
