Avoid Looping Issue
nasr.khan
Edge Switches are connected to BackBone-SW as trunk. Interfaces on EDGE switches are with portfast.
How to avoid looping concerns and disable interface if user connects hub,switch,router to ports on Edge-SW.
Backbone switch Cisco 4506
Edge switch cisco 2960
Jason Fraioli
Level 3
Level 3
This may be what you are looking for on your portfast interfaces.
spanning-tree portfast bpduguard default
edit: BPDUGuard will shut down the interface, and you can use the following commands the auto-recover the interface.
errdisable recovery cause bpduguard
errdisable recovery interval 180
Thanks.
Do I need to configure any commands on Backbone-SW.
What is ideal "MSTP Akka PVST" in my scenario.
One BackBone-Sw with 12 Edge-SW connected via SFP as trunk ports.
We have 45 Vlans including Voice/Data Vlans.
where does VTP Pruning fits??
Where does BpduFilter fits??
