Back up issue
pramod.prasad
Community Member
Hi ,
In my MEN network , we have two links on is over microLan by using router of 100 mbps and another is through bridge of 2mbps using static routes for both links but inspite of increasing the AD of one static route(no routing protocols are used) it will never give the back up of the main , can u advice the another way .
thanks
9 Replies 9
spremkumar
Level 11
Level 11
If the primary link is connected onto the ethernet port on both the sides untill unless you remove the link physically from the port.
You need to run a special mechanism called Object tracking to track your primary link and forward the traffic through thesecondary link based on the connection status.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbeb.html
You can refer the above link in configuring up the same..
regds
mlouis
Level 2
Level 2
How are you going about testing? Do you just perform a shut on one side of the link or both? Do you physically disconnect the cable on one or both ends?
Can you post your configuration pertaining to the interfaces and the static routes?
Maybe even the output from the "show ip route" during failover and during normal operation.
Pls find the output from the "show ip route" during normal operation.
and config also
How have you tested this failover. If the connection is failing between the two microlan devices then the line protocol on the interface attaching to your routers may not be going down. If this is the case the router will think that the primary route is still active and will continue to send traffic over that link into a blackhole.
One possible solution here is to use a routing protocol over both connections, such as eigrp. This would enable the router to learn about the intermediate link failure and adjust its routing table accordingly. The static route with higher AD option will only work if the interfaces on both sides of the link are aware of the intermediate link failure.
You can use conditional based policy routing to accomplish this as well. It uses a ping responder from the IP SLA software to test availability of remote ip address. If the ip becomes unavailable (possibly from a service interuption) conditional based policy routing will change the next hop ip address to the backup link next hop. You can set the thresholds for failover time and such.
As noted before this is essentially tracking an object (in this case a rtr ping responder availability) and using that the test the validity of the next hop. This is very common in scenarios where customers cannot run routing protocols over the internet to their service provider but require next hop redundancy to the internet.
Hope that helps.
Mike Louis
Dear Mike ,
Im little bit confused , I saw the config in below hyper link, hope it will work but IP policy should be implemented on Vlan1(management Vlan) ?Pls suggest
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml,
thanks
Pramod Prasad
is there any way that you can configuring ip routing protocol, like eigrp across both of these links? That would be a much easier approach.
Not sure what you mean by
"ip policy should be implemented on Vlan1"
can you clarify?
The policy routing used here is only for changing the next hop in the routing table. Just like a routing protocol on both ends would do. You are essentially saying
check availability of router 1 (primary remote device) using a ping check
if remote device responds use current default route and next hop
if remote device fails to respond then use this alternate default route and next hop
this is automating what an admin would have to do if the primary link failed in order to restore packet forwarding across the backup link. This configuration will do it for you.
i would really stress using a routing protocol if possible. The configuration is very simple. We could even use a tunnel configuration if service provider is a problem. Although we would have to adjust the mtu size on the tunnel but it would work and we could run routing protocols over the tunnel . Just another thought.
Mike
Hi Mike,
I got the point tht using the routing protocol is best option , but i have a constraint tht im not able do so i.e looking 4 the option tht will provide backup option using static routes which will be automating the backup process.
U r advicing the tunnel option but this option is feasible in Switch without using routing protocol? Is this option automate the backup process.
Pls suggesst.
Pramod Prasad
What ios version are you running on the wan routers?
At both ends there is 4507 catalyst switches , ONE LINK IS micro LAN first come to microlan bridge then extended to our catlyst , another link is by BG -40 first terminated at 3500 switch then extended to our catlyst.
both terminated on fastethernet of catalyst
