Bandwidth failure
Paul Webster
Level 2
Level 2
Greetings to all, yesterday I was doing a test on 2 cisco 2950 and 3750 switches and I got some worrying results ... when I transfer data from one PC to another the maximum bandwidth achieved is 11 mbps, it is important indicate that the switches have nothing configured and only these two machines are connected to the switch .. both with the same behavior .. however I place another desktop switch of another brand and lower performance and the bandwidth becomes up to 120 mbps .
My question is whether IOS versions may be creating this bottleneck on packages sent and received. this may be affecting performance and data traffic on the network
Here the Show Version for both Switches
IOS (tm) C3750 Software (C3750-I9-M), Version 12.1(14)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 02-Sep-03 05:15 by antonino
Image text-base: 0x00003000, data-base: 0x0079DB54
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(11r)AX, RELEASE SOFTWARE (fc1)
HWB-SW-002 uptime is 22 weeks, 7 hours, 0 minutes
System restarted at 10:48:06 UTC Wed Apr 3 2019
System image file is "flash:c3750-i9-mz.121.14-EA1a/c3750-i9-mz.121.14-EA1a.bin"
cisco WS-C3750-48TS (PowerPC405) processor (revision B0) with 118774K/12288K bytes of memory.
Processor board ID CAT0803X1EG
Last reset from power-on
1 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3 interface(s)
--More--  The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0F:23:C2:C2:80
Motherboard assembly number : 73-7056-09
Power supply part number : 341-0028-01
Motherboard serial number : CAT080212EM
Power supply serial number : LIT0704002A
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C3750-48TS-S
System serial number : CAT0803X1EG
SFP Module assembly part number : 73-7757-02
SFP Module revision Number : A0
SFP Module serial number : CAT08020E8U
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48TS 12.1(14)EA1a C3750-I9-M
Configuration register is 0xF
Cisco IOS Software, C2960 Software (C2960-LANLITEK9-M), Version 12.2(55)SE7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:22 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01400000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(53r)SEY3, RELEASE SOFTWARE (fc1)
HWB-SW-001 uptime is 24 minutes
System restarted at 17:26:17 UTC Wed Sep 4 2019
System image file is "flash:/c2960-lanlitek9-mz.122-55.SE7/c2960-lanlitek9-mz.122-55.SE7.bin"
--More--  compliance with U.S. and local country laws. By using this product you
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C2960-48TC-S (PowerPC405) processor (revision N0) with 65536K bytes of memory.
Processor board ID FCQ1725Y3V2
10 Virtual Ethernet interfaces
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : F8:4F:57:C0:93:00
Motherboard assembly number : 73-12596-06
Power supply part number : 341-0097-03
--More--  Motherboard serial number : FCQ172506M7
Power supply serial number : ALD1722B0ZK
Model revision number : N0
Model number : WS-C2960-48TC-S
System serial number : FCQ1725Y3V2
Top Assembly Part Number : 800-32804-02
Top Assembly Revision Number : C0
Version ID : V06
CLEI Code Number : COMSG00ARC
Hardware Board Revision Number : 0x0B
* 1 50 WS-C2960-48TC-S 12.2(55)SE7 C2960-LANLITEK9-M
PAWP
9 Replies 9
mattjones03
Level 6
Level 6
Hi Paul,
Just to clarify, are both PC's connected to the same switch, or do you have an uplink between the C2950 and C3750?
If the PC's are connected to the same switch, do you observe the same behaviour?
I did the tests on both switches separately to rule out the fault, it turned out that both behave the same. even if I make the connection between both switches the transmission performance is very poor
PAWP
Please could you provide a show interface for the interfaces which the PC's are connected to?
I performed the tests with the initial configuration of the switches .. and additionally with some modifications to the ports and the results were those mentioned above
HWB-SW-001#show run inter fa 0/1
Building configuration...
Current configuration : 249 bytes
interface FastEthernet0/1
description INTERNET
switchport mode trunk
switchport nonegotiate
speed 100
duplex full
storm-control broadcast level 20.00
storm-control action trap
spanning-tree bpdufilter enable
spanning-tree guard root
end
HWB-SW-001#
PAWP
Thanks for the information, however please could you provide the "show interface" output for the two interfaces connecting to the PC's.
My assumption at this stage is that you are experiencing a duplex issue, which could be causing the poor performance you have observed. To validate this assumption, I would need to see the output of "show interface" for both interfaces.
Here it is
HWB-SW-001#
HWB-SW-001#show interfaces | inc ^[A-Z]|duplex|drops
Vlan1 is up, line protocol is up
Vlan100 is up, line protocol is up
Vlan200 is up, line protocol is up
Vlan300 is up, line protocol is up
Vlan400 is up, line protocol is up
Vlan500 is up, line protocol is up
Vlan600 is up, line protocol is up
Vlan700 is up, line protocol is up
Vlan800 is up, line protocol is up
Vlan900 is up, line protocol is up
FastEthernet0/1 is up, line protocol is up (connected)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 9768
  FastEthernet0/2 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 151
FastEthernet0/3 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 480
FastEthernet0/4 is up, line protocol is up (connected)
FastEthernet0/5 is down, line protocol is down (notconnect)
FastEthernet0/6 is down, line protocol is down (notconnect)
FastEthernet0/7 is down, line protocol is down (notconnect)
FastEthernet0/8 is down, line protocol is down (notconnect)
FastEthernet0/9 is up, line protocol is up (connected)
FastEthernet0/10 is down, line protocol is down (notconnect)
FastEthernet0/11 is up, line protocol is up (connected)
FastEthernet0/12 is up, line protocol is up (connected)
FastEthernet0/13 is down, line protocol is down (notconnect)
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
FastEthernet0/14 is down, line protocol is down (notconnect)
FastEthernet0/15 is up, line protocol is up (connected)
FastEthernet0/16 is down, line protocol is down (notconnect)
FastEthernet0/17 is up, line protocol is up (connected)
FastEthernet0/18 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 400
FastEthernet0/19 is up, line protocol is up (connected)
FastEthernet0/20 is down, line protocol is down (notconnect)
FastEthernet0/21 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 732
FastEthernet0/22 is down, line protocol is down (notconnect)
FastEthernet0/23 is down, line protocol is down (notconnect)
FastEthernet0/24 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 58
  FastEthernet0/25 is down, line protocol is down (notconnect)
FastEthernet0/26 is up, line protocol is up (connected)
FastEthernet0/27 is up, line protocol is up (connected)
FastEthernet0/28 is down, line protocol is down (notconnect)
FastEthernet0/29 is down, line protocol is down (notconnect)
FastEthernet0/30 is down, line protocol is down (notconnect)
FastEthernet0/31 is up, line protocol is up (connected)
FastEthernet0/32 is up, line protocol is up (connected)
FastEthernet0/33 is up, line protocol is up (connected)
FastEthernet0/34 is down, line protocol is down (notconnect)
FastEthernet0/35 is down, line protocol is down (notconnect)
FastEthernet0/36 is up, line protocol is up (connected)
FastEthernet0/37 is down, line protocol is down (notconnect)
FastEthernet0/38 is up, line protocol is up (connected)
FastEthernet0/39 is down, line protocol is down (notconnect)
FastEthernet0/40 is down, line protocol is down (notconnect)
FastEthernet0/41 is down, line protocol is down (notconnect)
FastEthernet0/42 is down, line protocol is down (notconnect)
FastEthernet0/43 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 495
FastEthernet0/44 is up, line protocol is up (connected)
FastEthernet0/45 is up, line protocol is up (connected)
FastEthernet0/46 is down, line protocol is down (notconnect)
FastEthernet0/47 is down, line protocol is down (notconnect)
  FastEthernet0/48 is down, line protocol is down (notconnect)
GigabitEthernet0/1 is up, line protocol is up (connected)
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX
GigabitEthernet0/2 is up, line protocol is up (connected)
PAWP
HWB-SW-001#
HWB-SW-001#
HWB-SW-001#
PAWP
Thanks for the information.
I can see that some of the interfaces are experiencing output drops. Can you confirm the following;
1. Which interfaces do PC’s A and B connect to on the C3750?
2. Do both PC’s reside in the same VLAN?
3. What are the associated IP addresses and subnet of both PC’s?
I would suggest that you remove the speed and duplex statement from the interfaces connecting to the PC’s and allow this to be auto negotiated. If you want to statically assign this, ensure you do so on both sides (switch and PC).
If the PC’s are in different VLAN’s, please can you highlight the diagram you provided, with this information, and which device holds the L3 interfaces for the associated VLAN’s.
My Answres
Im using varius ports on the switch.
Yes
192.168.0.x / 24
The ports are forced tu full duplex like the PC
PAWP
