Bandwidth limitation Cisco 1921
Tommy Svensson
Hi.
I have the following setup:
Cisco 1921 is my core router and connectet to it is a 30 Mbit fiberline
VLAN1
VLAN2
Now, the thing is that i want VLAN2 to have a 5 Mbit bandwidth limit to Internet but full speed to VLAN1.
I have played around with Rate limit without success, any ideas hos to solve this?
I also have access to cisco switches that can limit the bandwidth if that helps.
Kind regards,
Tommy Svensson
23 Replies 23
Latchum Naidu
Hi Tommy,
You can achieve this with Policy-map.
See the below two individual steps may help in your scenario.
STEP-1:
Apply rate-limit on each L3 vlan interface in your 2851
Example (for 1024kbits for vlan 2):
Router# conf t
Router(config)# int vlan 2
Router(config-if)#rate-limit input 1000000 187500 375000 conform-action transmit exceed-action drop
Router(config-if)#rate-limit output 1000000 187500 375000 conform-action transmit exceed-action drop
STEP-2:
Policy a specific VLAN number on VLAN interface.
class-map vlan5
match vlan 5
match class-map class-default
policy-map vlan5-limit
class vlan5
police 2000000 250000 exceed-action drop
int vlan5
service-policy input vlan5-limit
After you apply this configuration, the traffic with VLAN 5 coming from any will be policed at 2Mbps.
Hope this will help you.
Please rate the helpfull posts.
Naidu.
Hi.
Im not really sure how to apply this to my case, today i have a rate limit set on the interface of VLAN2 as you did in STEP-1.
However, that does it so that VLAN2 has limited bandwidth to Internet and VLAN1. What i want is for VLAN2 to have full speed to VLAN1 and limited speed to the Internet.
Kind regards,
Tommy Svensson
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
There are a few things you might want to consider.
First, if you don't have access to the other side of the 30 Mbps link, you can't always ideally control inbound bandwidth.  You certainly can rate-limit inbound traffic, but that is after the traffic has already hit your device.  For example, 30 Mbps coming in can be limited to 5 Mbps going to Vlan2, but I assume you really want to limit Vlan2's usage of the 30 Mbps to only 5 Mbps.  In fact you can't, although if the inbound traffic is TCP, it should slow itself as you drop its packets with a rate limiter.
Second, rate-limiters are very severe, as in they drop all packets that exceed the limit.  TCP doesn't mind too much, but non-TCP traffic can be totally disrupted by a high drop rate.
An alternative to rate-limiting is shaper.  With a shaper, traffic rate is also controlled, but excess traffic is buffered.  A shaper's impact to traffic is closer to an interface of the same bandwidth.  Unfortunately, shapers can only be used outbound.
An an alternative to shaping, also for egress, advanced queuing might be used.  This could allow, for example either Vlan to use all 30 Mbps, but if both wanted it all, it can insure Vlan1 gets 25 Mbps while Vlan2 only gets 5 Mbps.
How to do any of the above would depend on your topology and actual needs.  You do need to be clear about what you want to accomplish, for instance Naidu's example would limit Vlan5 interface to 2 Mbps, but this would apply to all its off Vlan traffic, not just to the Internet traffic, nor does it limit what this Vlan can "pull" from the Internet.
Hi.
I am clear of what i want to accomplish here.
I want so that VLAN2 has full speed to VLAN1 and that VLAN2 has limited speed to the Internet.
What would be the ideal way to accomplish this?
Kind regards,
Tommy Svensson
hi tommy,
your requirement
1. Traffic between internet and Vlan 2 -  limited to 5Mbps
2  Traffic from  Vlan 1 to Vlan 2-   no limit
Now, the way your rquirement is pretty hard to achieve given that once you rate limit Vlan 2 it will affect the whole Vlan if you know what I mean. Is there a very strong reason you need to do this?
The rate limit is not necessary at all, i just want the described functionality.
Kind regards,
Tommy
Hi Tommy,
I like your curiosity
ok how about this solution.
+++on the router
access-list 100 < match the Vlan 2 users here>
class-map VLAN2
match access-group 100
policy-map LIMIT_VLAN2_5MBPS
class VLAN2
  shape average 5000000
interface < link to the ISP>
service output LIMIT_VLAN2_5MBPS
1 This would  sort of rate limit(shape) the traffic of Vlan 2 to 5Mbps. This achieves your first condition
2. Because they will be on a trunk port to a layer 2 switch both vlan's can have full access to each other without any limit.
Hope the above gives you some idea of what I am talking about
Kishore
The 3 interfaces is already part of security zones and i use a ZBF, is it still possible to apply another ACL on my WAN interface?
Kind regards,
Tommy
Hi Tommy,
techincally its not an ACL. Its a service policy so you should be able to apply it. If you can share your config of the router maybe i can tell you more
Kishore
Hi.
This is what i have done so far.
interface GigabitEthernet0/1.21
encapsulation dot1Q 21
ip address 10.0.21.254 255.255.255.0
ip nat inside
ip virtual-reassembly
zone-member security VLAN21_ZONE
access-list 100 permit ip 10.0.21.0 0.0.0.255 any
class-map match-all LIMIT_VLAN21
policy-map LIMIT_VLAN21_5MBIT
class LIMIT_VLAN21
interface GigabitEthernet0/0
description WAN
ip address xxx.xxx.xx.194 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
zone-member security WAN_ZONE
duplex auto
speed auto
no mop enabled
crypto map VPNMAP
service-policy output LIMIT_VLAN21_5MBIT
Even though im on the VLAN21 subnet i cant seem to get hits on access-list 100. So my limitation is not working and im going out on the Internet att full speed.
Any thoughts?
Kind regards,
Tommy
Tommy,
Can you do a " sh policy-map interface GigabitEthernet0/0" and paste the results here. Also try to download some big files or videos or whatever for testing and do the command i mentioned an paste the results here.
Here it is.
Im not in office right now but i will try to download big files and type in the command again later.
GigabitEthernet0/0
  Service-policy output: LIMIT_MGNS_5MBIT
    Class-map: MGNS (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group 100
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      shape (average) cir 5000000, bc 20000, be 20000
      target shape rate 5000000
    Class-map: class-default (match-any)
      31569834 packets, 14342194992 bytes
      5 minute offered rate 2000000 bps, drop rate 0 bps
      Match: any
      (pkts output/bytes output) 31564456/14343562742
Can you make something out of this?
Kind regards,
Tommy
umm.. the config I have given you works but it restricts traffic from your network(Vlan2) to the outside world.I have tested this before and it works. But, you need to rate-limit the traffic coming from the internet into your vlan2.
So , we need to police it I have labbed it and I will put the paste the configs here for you ok?
   network is very simple
R3----------(your LAN)R1(Your WAN)------------R2(internet)
R3
R3#sh run
ip cef
interface GigabitEthernet1/0
ip address 10.0.21.1 255.255.255.0
negotiation auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.21.254
R1
R1#sh run
  class LIMIT_VLAN21
   police 64000 conform-action transmit  exceed-action drop
ip nat outside
negotiation auto
service-policy input LIMIT_VLAN21_5MBIT
interface GigabitEthernet2/0
negotiation auto
ip nat inside source route-map ALLOW interface GigabitEthernet1/0 overload
access-list 100 permit ip any 10.0.21.0 0.0.0.255
access-list 102 permit ip 10.0.21.0 0.0.0.255 any
route-map ALLOW permit 10
match ip address 102
R2
R2#sh run
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
ip address 192.168.1.2 255.255.255.0
negotiation auto
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
I will post the results in my next post
Now when I ping from R2(internet) to the LAN its pretty much like downloading a file. As you can see the NAT works good . Here 192.168.1.1 is your WAN IP
R2#ping 10.0.21.254 re 1000 size 1500      ,< pinging your LAN GW
Sending 1000, 1500-byte ICMP Echos to 10.0.21.254, timeout is 2 seconds:
Success rate is 75 percent (28/37), round-trip min/avg/max = 92/167/268 ms
R1#
*Oct 27 21:41:08.331: NAT: s=10.0.21.254->192.168.1.1, d=192.168.1.2 [44]
*Oct 27 21:41:08.619: NAT: s=10.0.21.254->192.168.1.1, d=192.168.1.2 [45]
*Oct 27 21:41:08.799: NAT: s=10.0.21.254->192.168.1.1, d=192.168.1.2 [46]
*Oct 27 21:41:08.971: NAT: s=10.0.21.254->192.168.1.1, d=192.168.1.2 [47]
R1#
*Oct 27 21:41:11.091: NAT: s=10.0.21.254->192.168.1.1, d=192.168.1.2 [49]
*Oct 27 21:41:11.231: NAT: s=10.0.21.254->192.168.1.1, d=192.168.1.2 [50]
Here you can see that the policer drops anything going above 64kbps. I have set a policer that says that anything more than 64kbps should be dropped
R1#sh policy-map int gi1/0
GigabitEthernet1/0
  Service-policy input: LIMIT_VLAN21_5MBIT
    Class-map: LIMIT_VLAN21 (match-all)
      37 packets, 56018 bytes
      5 minute offered rate 4000 bps, drop rate 2000 bps
      police:
          cir 64000 bps, bc 2000 bytes
        conformed 28 packets, 42392 bytes; actions:
          transmit
        exceeded 9 packets, 13626 bytes; actions:
          drop
        conformed 4000 bps, exceed 2000 bps
      0 packets, 0 bytes
      Match: any
Hope this gives you the idea of policing stuff coming from the internet into you Vlan 2.
Kishore
