setup a switch port for 2 vlans
huwyhuwy123
hi there,
I'm trying to setup a port on a catalyst 3750 so it will pass traffic for 2 vlans. It connects to a (watchguard) firewall which I've configured with a primary IP (for vlan 27) and a secondary IP (for vlan 29).
However I can't seem to find the correct commands to enter on the cisco switch port (I've tried a variety). Can anyone help?
Cheers,
Al
FYI the current configuration is...
interface FastEthernet1/0/38
description ## Connection to WG vlan27 and vlan 29 ##
switchport trunk native vlan 27
switchport trunk allowed vlan 27,29
switchport mode trunk
switchport nonegotiate
no logging event link-status
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
priority-queue out
mls qos trust cos
auto qos voip trust
no mdix auto
spanning-tree portfast
spanning-tree bpduguard enable
2 Accepted Solutions
Hi Alain,
The suggestion I provided is for the 3750 side of the connection.  I am not sure if the watchguard is capable to do dot.1q. According to this PDF it is, If not, then as you noted it is not going to work.
http://www.watchguard.com/help/docs/edge/10/v101edgeuserguide.pdf
Reza
I looked at the watchguard document and it support 802.1Q
Why dont you use the same trunking method at both ends.
Please rate the helpfull posts.
Naidu.
8 Replies 8
huwyhuwy123
I should add that the above works for vlan27 (i.e. I can ping the firewall) but not for vlan 29.
You need to have both the Layer 2 (VLAN) and Layer 3 (network) settings matching up on both the switch and firewall. I suspect you may not be negotiating a trunking protocol and are thus sending frames untagged to the firewall on Vlan 27 (as a result of the 'switchport trunk native vlan 27' line). Thus when you address a Layer 3 IP from the range served up on Vlan 29 you get no reply.
Hope this helps.
Reza Sharifi
To make a port a trunk port, these are the only commands you need:
so, test with this config and provide the results.
Hi reza,
I don't think it will work if he doesn't do 802.1Q on the Watchguard which he isn't doing now.
Regards.
Alain
Hi Alain,
Reza
Thanks for all the replies. I really appreciate your help.
Are you guys saying that if the watchguard doesn't support dot1q then it won't work? Is there a way to pass traffic from both vlans untagged?
The watchguard is an XTM505 btw.
Cheers again,
Al
Naidu.
Thanks guys. I setup vlan tagging on the watchguard and got this working.
Cheers again,
Al
