Banwidth limiting using QOS
jaimonmathew
Frequent Visitor
Frequent Visitor
Is it possible to limit the bandwidth in different VLAn's using QOS..
i have 5MBPS internet connection ,with 254 public IP I did subnetting for this pool made separate vlan for each public subnet i have to share this connection in different VLAn's, ie is for different clients.. using one cisco 4506 switch.. For eg... for one client 256 kbps, the other one for 512 kbps..
6 Replies 6
Mohamed Sobair
Level 11
Level 11
You can configure Policing or Shaping whatever method you want to use at the SVI (The Vlan Interface itself) and limit ur bandwidth accordingly.
Mohamed Sobair
Can u Give some example for that
Jaimon
here is a (Policing) example, assumed u are limiting the bandwidth at vlan 10 interface to 256Kbps:-
class-map match-any vlan10
match access-group 100
access-list 100 permit ip any any
policy-map vlan10 (Rate limited at 256Kbps)
class vlan10
police 256000000 32000 action transmit exceed action drop
int vlan 10
service-policy output vlan10
Mohamed Sobair
Is the police command correct? Should it not be:
police 256000 32000 action transmit exceed action drop
Yes , you are right...
I think I have misatkenly typed it with extra 3 Zeros. Hence it in Bps , so it should be 256000.
Mohamed Sobair
Thank u .Its Working
