Basic network configuration
beginner1
Visitor
I've configured the below network using Class C addresses. Can someone help me in configuring the same using any Class A and Class B address?
Ps- I'm very new to using Cisco Packet tracer.
I've attached the file along with configuration details below.
luis_cordova
Hi @beginner1,
In simple words:
The classes of private networks are:
A: 10.0.0.0-10.255.255.255 /8
B: 172.16.0.0-172.31.255.255 /16
C: 192.168.0.0-192.168.0.255 /24
Therefore, if you only want to change your class C networks, just change the first two octets of the all yours IP.
Example:
192.168.1.1/24 => 172.16.1.1/16
or
192.168.1.1/24 => 10.0.1.1/8
5 Replies 5
Georg Pauwen
I think I remember you asking this question before ? Either way, Class A and Class B can either be public or private space addresses...which ones do you need ?
I'm not very sure about the difference between Public and private space addresses.
I need something similar to the class C configuration that I've already done.
luis_cordova
Hi @beginner1,
In simple words:
Example:
or
Hi ,
its really simple just read the available privates IPs blocks and configure from any class A,B or C.
https://en.wikipedia.org/wiki/Private_network
BR
Tayyab
*** Please rate all helpful responses and mark solutions***
check the below link for the available block from class A and configure.
BR
Tayyab
