BB Switch Advice
vishal.rane
Hello
Our 4 different group will be sharing the same office floor  which was scattered earlier in different cities. Total number of Users would be around 100 and I already got 3 switches 2960 (48 ports ). Can someone suggest a good backbone switch where i plan to terminate all switches and create vlan. I will be responsible to manage all switches, ip address schema and support users.
Any suggestion
thanks
Vishal
vishal.rane
Hello
Are there any comparison tool from cisco to compare catalyst 3560 with 4500
Joseph W. Doherty
Disclaimer
The      Author of this posting offers the information contained within this      posting without consideration and with the reader's understanding   that    there's no implied or expressed suitability or fitness for any    purpose.   Information provided is for informational purposes only  and   should not   be construed as rendering professional advice of any  kind.   Usage of  this  posting's information is solely at reader's own  risk.
Liability Disclaimer
In      no event shall Author be liable for any damages whatsoever    (including,   without limitation, damages for loss of use, data or    profit) arising  out  of the use or inability to use the posting's    information even if  Author  has been advised of the possibility of   such  damage.
Posting
L2 or L3?  Links between switches copper or fiber?  Edge ports FastEthernet or GigEthernet?  Expected traffic load?
For L2 you could use another 2960.  For redundancy, dual (stacked) 2960-S.
For L3 you could use one of the 3650 models, for redundancy, dual pair (stacked) of one of the 3750 models.
PS:
BTW, believe the latest IOS for some of the 2960s (-S models?) support very basic L3.
