BDI and HOSTFLAPPING
dia khateeb
Frequent Visitor
Frequent Visitor
Dears, i have an isr4431, and I'm configuring a BDI interface to ensure redundancy in case a leg went down.
below the config i used in the router:
spanning-tree mode rapid-pvst
inter BDI100
ip address 192.168.1.254 255.255.255.0
interface GigabitEthernet0/0/0
 no ip address
 negotiation auto
 service instance 100 ethernet
  encapsulation dot1q 100
  rewrite ingress tag pop 1 symmetric
  bridge-domain 100
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
  bridge-domain 100
switch configuration was:
interface GigabitEthernet1/1/1
 description 4431 Leg1
 switchport trunk allowed vlan 100
 switchport mode trunk
 spanning-tree guard loop
interface GigabitEthernet2/1/1
 description 4431 Leg2
spanning tree from router side on this vlan is:
4431#sh spanning-tree vlan 100
G1:VLAN0100
  Spanning tree enabled protocol rstp
  Root ID    Priority    100
             Address     0008.e3ff.fc28
             Cost        4
             Port        8 (GigabitEthernet0/0/0)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32770  (priority 32768 sys-id-ext 2)
             Address     0027.e37a.20a2
             Aging Time 0
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/0/0             Root FWD 4         128.8    P2p Peer(STP)
Gi0/0/1             Altn BLK 4           128.9    P2p Peer(STP)
now, when i disconnect/reconnect the Gi0/0/1 nothing happens to the traffic.
when i disconnect the Gi0/0/0 one ping is dropped only, and after reconnecting it, spanning tree works on making the Gi0/0/0 a root interface, i receive a couple of HOSTFLAPPING errors on the switch then all return to normal, and around 8 pings are lost.
is this normal! are there any way prevent this error when the root link is reconnected, should i be concerned of future HOSTFLAPPING, especially that I'm going to make this router a spoke for a DMVPN.
thanks in advance.
Georg Pauwen
try to add the line in bold to your configuration and check if that makes a difference:
inter BDI100
no ip address
negotiation auto
l2protocol peer stp
bridge-domain 100
no ip address
negotiation auto
l2protocol peer stp
bridge-domain 100
Hi Georg
Thnx for your reply, i tested it and got same results.
I'm thinking, is there a way to make stp NOT to re-learn the network after
reconnecting GE0/0/0, keeping the active port as fwd and making the
reconnected port a blk?
