Bookmark
Subscribe
354
bgp failover question , igp is eigrp
gavin han
Hi All,
as shown in below diagram. I have to configure where traffic will automatically failover if link goes down. A-R2 <->B-R2 link as to be primary. if that link goes down than traffic should automatically failover to A-R1 <->B-R1 link. once A-R2 <->B-R2 link is back up then traffic should flow through A-R2 <->B-R2 link. how to accomplish this? B-R1 and B-R2 are running eigrp as well, so bgp routes are redistributed into eigrp. bgp admin distance is set to 200 200 200 for internal, external routes. how to accomplish this failover?
gavin han
could someone advise please? how to configure it so that routes through B-R2 will always be preferred? if B-R2 goes down then traffic would failover to B-R1 but traffic should failback to B-R2 as soon as B-R2 comes back up. how to accomplish this? please help.
You want that B-R2 is selected as default part from other eigrp peers? If yes when redistributing bgp routed into eigrp setup a preferred metric on b-r2 than b-r1. All eigrp peers will take this path instead the other. If b-r2 goes down then the path will be through b-r1.
Could you take 1 subnet that both bgp are redistributing into eigrp and on 1 of the other eigrp peer do the following (paste please the output):
- sh ip route of that subnet
- sh ip eigrp topology of that subnet
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
