BGP on Cisco 3750E
Rajeev Ranjan
Dear Friends.
I need to use cisco 3750E switch on core. I want to know whether BGP is supported on this model or not?
Currently i have c3750e-universalk9-mz.150-2.SE/c3750e-universalk9-mz.150-2.SE.bin" preinstalled. and i checked BGP is not supported on this IOS image. Please help me.
2 Accepted Solutions
Yes, from sh ver your license level is IP base
License Level: ipbase
License Type: Permanent
Talk to your sales guy, and purchase IP Services license.  That is all you need.  You don't need to change the IOS.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-579326_ps10745_Products_White_Paper.html
You don't need to upgrade.  You are already running one of the latest version.  Upgrading is not going to enable IP Services license.  You would need to buy the license and install it on the switch.
You can use this link to get a 90 trail license.  This gives enough time to purchase the permanent license.
https://tools.cisco.com/SWIFT/LicensingUI/Home
7 Replies 7
Reza Sharifi
BGP is supported on 3750 series switches, but you need IP Services license before you can enable it.
You probebly currently have IP Base license
can you post "sh lice" and "sh ver"?
Please find the show version output.
Switch>sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 27-Jul-12 23:26 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
Switch uptime is 2 days, 1 hour, 13 minutes
System image file is "flash:c3750e-universalk9-mz.150-2.SE/c3750e-universalk9-mz.150-2.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Next reload license Level: ipbase
cisco WS-C3750X-24P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1638R2G0
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : E4:D3:F1:34:FD:80
Motherboard assembly number     : 73-12551-06
Motherboard serial number       : FDO16381TLM
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-24P-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO16380YQX
System serial number            : FDO1638R2G0
Top Assembly Part Number        : 800-31325-03
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                : COMJR00ARC
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24P      15.0(2)SE             C3750E-UNIVERSALK9-M
Configuration register is 0xF
Thanks Reza...
Can i upgrade IOS image rather than purchasing IP Services license? We dont have enough time to chase.
Rajeev,
If the answers have been helpful, please rate the post and mark it as answered so others can benefit from it.
Thanks for your great help.
