vss with modules
Ibrahim Jamil
Level 7
Level 7
i m going to convert my two  6500 to VSS , i have the below module on each 6500 . does the VSS work fine and well with modules listed below?? , pls give me video for VSS implenatation and verifactions
1   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  2   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  3   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  4   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G
  7    3  Network Analysis Module                WS-SVC-NAM-1-250S
  8    6  Firewall Module                        WS-SVC-FWM-1
  9   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP
thanks to all
ibtahim
8 Replies 8
Giuseppe Larosa
Hello Ibrahim,
6148 are not supported in VSS and they will be left unpowered you should change them with 6748 modules like the one in last slot.
FWSM and NAM are service modules and require appropriate minimum firmware version to be supported in VSS you should upgrade them first if necessary.
see
! VSS FAQ
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b_ps2797_Products_Q_and_A_Item.html
! design with VSS
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/VSS30dg/VSS-dg_ch3.html
! integration of service modules in VSS
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c72b.shtml
here see the first table that provides the minimal firmware version for each type of service module
4.0.4 for FWSM and  3.6.(1a) for NAM
! migration guide from standalone to VSS follow carefully this document
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c74c.shtml
! VSS product page
http://www.cisco.com/en/US/products/ps9336/index.html
Hope to help
Giuseppe
Hello Giuseppe
Million thanks my freind , you save my job , God Bless you
thanks
Ibrahim
Hi Giuseppe
i have question pls
would you please give documentation for 6148 , that mentioned not isn't support VSS ,
i m happy coz our module X6748-GE-TX support vss
thanks
Ibrahim,
Only the 67xx , 68xx and 69xx series line cards support VSS. The 61xx series do not support VSS.
Reza
mahmoodmkl
Level 11
Level 11
and just to add to the other posts make sure tht they have dfc3c
Hi Riza Hi mahmood , i need documents to show it to my Boss
thanks
Ibrahim,
show your boss table-1 in this link and ask him for a raise.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b.html
Hardware and Software Requirements and Restrictions
Hi Reza
this link  already provided by Giuseppe
thanks
