each port is a trunk and carry the same VLAN
Ibrahim Jamil
Level 6
Level 6
can i have 4 links from an ESX server to 6500 , each link represents a trunk link carries each the same 2 VLAN , 100 and 101 , keep port-channel out of the picture , does it work well???
thanks
Ibrahim
12 Replies 12
John Blakley
Jamil,
It works. We have ESX servers that have multiple vlans configured on the ports they connect to. I can't help with the ESX portion of the setup because I don't do that side of things, but I can assure you that I don't have channel-groups configured for these servers.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi Jhon
i mean the same VLANs on each trunk port like below, how come>
6500
int g0/0
sw tunk encap do1q
sw mod trunk
sw trun allow vlan 10,20
int g0/1
sw tunk encap do1q
sw mod trunk
int g0/2
sw tunk encap do1q
sw mod trunk
thanks
Yes, it works:
interface GigabitEthernet2/47
switchport
switchport trunk allowed vlan 1,110,126,131
switchport mode trunk
storm-control broadcast level 0.05
storm-control multicast level 0.05
end
interface GigabitEthernet4/45
switchport
end
interface GigabitEthernet4/48
switchport
These are from my switch. I have a single VM server (all of ours use 6 links: 5 trunked and a service console) attached to these ports.
HTH,
John
thanks john , one question pls, what is the drawback of this config without a port-channel ?
Here's a link that may be able to explain better than I can:
http://serverfault.com/questions/215341/vmware-networking-portchannel-or-not (Older document)
This is from VMWare:
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1004048
As far as the server itself is concerned and to which is better, I can't tell you for sure since I don't work on the vmware servers. I believe we use vmotion which moves a vm to another server should that link go down. If you're using etherchannels, you'll be able to use all of the links, but you'll still never get more than 1Gb even if you have 4 ports in the etherchannel (the data can still only go so fast). I'm not sure how that translates to using multiple trunks vs etherchannel because our server team has never asked for etherchannels to be created. Although, now you have me curious and I may go ask them why we've never done it...
HTH,
John
thanks jhon
In addition to Jhon's post all the link can work if they are connected to VSS.
I seen issue with mac-flapping messages on the switches where the VM's are deployed.
Hi Jhon , Hi mahmood
in my case i dont have VSS ,  how did you solved the mac-flapping?
thanks
mahmoodmkl
Level 7
Level 7
this cannot be solved as vms are moved from time to time by the server guys which u cannot control
what about the non VSS ?
thanks
mahmoodmkl
Level 7
Level 7
in our scenario we configured port channels and the same was done from blade enclosure side for non vss but the above issue is for non vss for vss this not the issue
thanks mahmood , see you in other thread
