Bill of Material (BOM)
ibegbu.david1
Please, i need a BOM for the below:
Part Number Qty
WS-C4500X-16SFP+ 2
CON-SNT-WSC16SFX 2
C4KX-PWR-750AC-R 2
C4KX-NM-BLANK 2
C4KX-PWR-BLANK 2
C4500X-IPB 2
CAB-BS1363-C15-UK 2
S45XU-39E 2
C1-WS3850-12S/K9 4
CON-SNT-38012SK9 4
S3850UK9-163 4
C3850-NM-2-10G 4
CAB-TA-UK 4
STACK-T1-50CM 4
CAB-SPWR-30CM 4
PWR-C1-BLANK 4
PWR-C1-350WAC 4
L-C3850-RTU= 4
L-C3850-12-S-E 4
C1FPCAT38503K9 4
CON-ECMU-C1FC3853 4
C1-PI-LFAS-2K3K-K9 4
C1-ISE-BASE-12P 4
C1F1VCAT38503-04 4
WS-C2960X-24PS-L 12
CON-SNT-WSC224SL 12
CAB-ACU 12
CAB-CONSOLE-USB 12
NETWORK-PNP-LIC 12
C2960X-STACK 12
CAB-STK-E-0.5M 12
WS-C2960X-24PD-L 2
CON-SNT-WSC604DL 2
CAB-ACU 2
CAB-CONSOLE-USB 2
NETWORK-PNP-LIC 2
C2960X-STACK 2
CAB-STK-E-0.5M 2
WS-C3560CX-12PC-S 14
CON-SNT-WSC312PC 14
CAB-TA-UK 14
ISR4331-V/K9 1
CON-SSSNT-ISR4331V 1
SL-4330-IPB-K9 1
SL-4330-UC-K9 1
NETWORK-PNP-LIC 1
MEM-4300-4GU8G 1
MEM-FLSH-4U16G 1
PWR-4330-AC 1
CAB-ACU 1
CAB-CONSOLE-USB 1
PVDM4-32 1
NIM-BLANK 4
FL-CUBEE-5 4
SL-4330-SEC-K9 1
SM-S-BLANK 1
CME-UL 100
CON-ECMUS-CMEULCTG 100
SISR4300UK9-316S 1
ISR4331-SEC/K9 2
CON-SSSNT-ISR4331S 2
SL-4330-IPB-K9 2
NETWORK-PNP-LIC 2
FL-4330-HSEC-K9 2
MEM-4300-4GU8G 2
MEM-FLSH-4U8G 2
NIM-2GE-CU-SFP 2
NIM-ES2-4 2
PWR-4330-AC 2
CAB-ACU 2
CAB-CONSOLE-USB 2
SL-4330-SEC-K9 2
SM-S-BLANK 2
SISR4300UK9-316S 2
CP-7821-K9= 50
CON-SNT-CP7821K9 50
AIR-CT3504-K9 2
CON-SNT-AIRCTRTK 2
LIC-CT3504-1A 70
CON-ECMU-LICCTCTA 70
AIR-CT3504-SW-8.5 2
CON-SNT-AIRWCT354 2
CAB-AC-C5-UK 2
PWR-115W-AC 2
AIR-AP1832I-E-K9C 35
CON-SNT-AIRAPEKC 35
AIR-CMX-CLD-CPA-1Y 35
AIR-AP-T-RAIL-R 35
AIR-AP-BRACKET-1 35
SW1830-MECPWP-K9 35
SFP-10G-SR= 34
GLC-SX-MMD= 48
  200
BE6M-M5-K9 2
CON-SNT-BE6MM5K9 2
BE6K-PSU 2
BE6K-RAIDCTRLR 2
BE6K-DISK 12
R2XX-RAID5 2
BE6K-RAM 6
BE6K-CPU 2
CAB-9K10A-UK 2
VMW-VS6-HYPPLS-K9 2
R-CBE6K-K9 2
CON-ECMU-RCBE6KK 2
BE6K-SW-11.5-XU 2
BE6K-START-UWL35 2
BE6K-UWL-STD 200
UCM-11X-UWLSTD 465
CON-ECMU-UCM11STD 200
UCXN-11X-SCPORTS 4
UCXN-11X-UWLSTD 465
LIC-EXP-E-PAK 2
LIC-EXP-GW 8
LIC-EXP-E 4
LIC-EXP-TURN 4
LIC-EXP-AN 4
LIC-SW-EXP-K9 8
LIC-EXP-SERIES 8
EXPWY-VE-E-K9 4
BE-11X-UWLS-STR 2
CON-ECMU-BE11WXUR 2
BE6K-UXL-START 2
EXPWY-VE-C-K9 4
SW-EXP-8.X-K9 2
BE6K-PAK 2
LIC-EXP-DSK 465
Awaiting kind responses.
balaji.bandi
personally suggest to contact local cisco sales partner, who can guide you better, so you do not miss any material while you deploying the same.
BB
