Block a destination via switch
emadehsan
I have a 2950 Enhanced image catalyst switch
my goal is that do something to make only one destination (sepecific host) available for my source address clients.
how can I use access-list for this issue?
7 Replies 7
ankbhasi
Hi Friend,
You can configure extended access list and apply on to the physical interfaces
Check this link for more details
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12120ea2/2950scg/swacl.htm#wp1092483
Ankur
i have this config on my switch but i seems it doesnt work
access-list 101 permit any 172.16.100.70 0.0.0.255
i have also access-group command on the interface.
"172.16.100.70 is my target for clients"
Hi Friend,
What are the results...are the clients able to reach everybody I mean something other than 172.16 network?
Ankur
ACLs applied to a physical interface has a limitation of one mask
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12120ea2/2950scg/swacl.htm#wp1082773
Narayan
try applying below statement in the access list and apply it in the interface.
access-list 101 permit any host 172.16.100.70 log
try to access this host from few PCs and check your ACL if it is getting hit.
Do not use logging (log keyword) in switches access-lists - all packets matching access-list rows with log keyword must be sent to CPU instead of processing in hardware. This will significantly degrade the switches performace.
//Mikhail Galiulin
your acl does not make sense..
You have are defining a host address, but a /24 mask...
it should be access-list 101 permit any host 172.16.100.70
Jens
