Block rdp access on my switch
ohareka70
Level 3
Level 3
I am trying to block access from switch on vlan7 outbound for tcp/3389.  My IP is 10.230.1.99
interface Vlan7
ip address 10.230.1.220 255.255.255.192
ip access-group BLOCK_RDP in
ip access-group BLOCK_RDP out
ip access-list extended BLOCK_RDP
deny   tcp any any eq 3389
deny   udp any any eq 3389
permit ip any any
access-list 11 permit 10.230.1.99
I am not getting any matches though and RDP access is still working
#sh ip access-lists
Extended IP access list BLOCK_RDP
    10 deny tcp any any eq 3389
    30 deny udp any any eq 3389
    40 permit ip any any (151 matches)
2 Accepted Solutions
Hello
I suppose you can do it from the host pc that you want to deny access with a fw rule or something but not from the L2 switch
To negate RDP from a host on the network the access-list has to be on a routed (l3) interface of the device performing the routing, The L3 interface on a L2 switch is just for mgt access to the switch nothing more.
Kind Regards
Paul
L2 Switch  NO in short answer, ACL required to be applied always @ L3 interface where the traffic passing.
BB
23 Replies 23
balaji.bandi
what is the gateway for this IP address : 10.230.1.99  ( i do not believe this is part of the subnet of VLAN7)
can you post ipconfig/all from PC output ?
BB
ip default-gateway 10.230.7.254
I have posted a config above
Hello
interface Vlan7
permit ip any any
#sh ip access-lists
Reason being the host is in the wrong subnet for vlan 7 so the acl appended to the svi vlan 7 inst being matched for that host:
10.230.1.99/26 - hosts  10.230.1.66 -126
10.230.1.220/26 -  hosts 10.230.1.193 -254  =  vlan 7
Kind Regards
Paul
Paul,
I have changed the IP address to .70 now but still not hits for blocking port 3389
I have posted the config if you dont mind taking a look
SW03#sh run
version 15.2
no ip source-route
no ip gratuitous-arps
vtp domain ttttt
vtp mode transparent
mls qos
vlan 2-7,9,12,14-16
vlan 21
name WIFI_USRS
vlan 257
name voice
vlan 500-501
lldp run
interface GigabitEthernet1/0/1
description Phone and PC
switchport access vlan 7
switchport mode access
switchport voice vlan 257
priority-queue out
no snmp trap link-status
mls qos trust dscp
spanning-tree portfast
spanning-tree bpduguard enable
etc
interface GigabitEthernet1/0/49
description primary uplink
switchport trunk allowed vlan 1,7,8,20,21,257
switchport mode trunk
interface GigabitEthernet1/0/50
description Sw-L3-01
interface Vlan1
description Mgmt VLAN
ip address 10.230.31.7 255.255.255.0 secondary
ip address 10.230.7.198 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface Vlan7
ip address 10.230.1.70 255.255.255.192
permit ip any any
vstack
what is the target IP address for the RDP traffic that is supposed to be blocked ? Are the 'ip any any' hits increasing in sync with your attempts to connect through RDP ? Do a 'debug ip packet' and post the output here during an attempt to connect through RDP...
Hello
do you have ip routing enabled on the switch - can your host ping all the l3 svi's of the switch
How are you testing this? - a telnet session on port 3389 to the svi 7 of the switch and if so how have you created a rdp session on the switch?
or do you have an additional host on this vlan that is rdp active?
Kind Regards
Paul
Yes - i can ping all SVI's which are on the layer 3 distribution switch (next hop)
Show access-lists
    40 permit ip any any (9821 matches) THIS IS INCREASING
BRECOMSW03#debug ip packet
IP packet debugging is on
NOTHING SHOWING
Maybe the problem is i am connected on this switch with my laptop via port 37 and i am trying to block microsoft rdp access from my laptop to 10.224.3.157 but though i could do it at switch level
where is the Vlan for 10.224.3.157 ? You are missing something fundamental. Post the full running configuration of the switch (sh run)...
This IP is from a different Office.  I can ping that IP and remote on the server ok.  What i want to do is restrict tcp/3389 from the local switch to it.  Is that possible?
Try and apply the access list to the Vlan 1 interface:
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
Sorry but that didnt work
ok Not sure you hit the right gateway here.
here is my understanding and like to know more inputs from you :
PC has IP address  - 10.230.1.99
Which is connected same Switch port  37 ( can you post the Port 37 config ) - suggest to post full config of the switch. ( show run)
what is the 10.230.1.99  gateway (is this static configured or getting from DHCP) - can you post ipconfig /all  screenshot
from PC can you also send the output traceroute 10.224.3.157
BB
I have attached what you require
I think their is something not right with the deny statement
Hello
You should be able to and that acl looks applicable to do so also for inter-vlan routing! you may need to apply the acl to the vlan that is connecting upstream towards your wan, however can you first clarify ---
You have a host 10.230.1.99/26 in a access port assigned to vlan 7  pointing to a D/G 10.230.1.70/26 which is the L3 SVI of vlan 7 that resides on the L3 switch and you are testing a RDP connection initiated from this host 10.230.1.99 towards 10.224.3.157- correct ?
Kind Regards
Paul
