Block traffic for single vlan
SSibu
hello,
i have one cisco L3 switch with following configuration,
vlan 2: 192.168.2.1
vlan 3: 192.168.3.1
vlan 4: 192.168.4.1
I want to disable port2 to access vlan 3 only.  but access vlan 2 and 4.
kindly advice
2 Accepted Solutions
balaji.bandi
IN = Traffic originating from within the vlan interface
OUT = Traffic coming from outside vlan interface
Example : you can do  as below (if you looking to log for verification all working add log end of rule)
ip access-list extended VLAN2
deny ip 192.168.2.0 0.255.255.255 192.168.3.0 0.0.0.255
permit ip any any
interface vlan 2
ip access-list VLAN2 in
BB
- If You want to disable a port then first add that port in a VLAN , Let's say you added , port 2 in VLAN 5 : 192.168.5.1 ( you can add the port in a new VLAN or can add it in any existing VLAN as per your requirement ) .
  int f0/2
switchport mode access
switchport access vlan 5
Now the port is added in Vlan 5
Now we can use an ACL to block VLAN 5 from accessing VLAN 3 , but will be allowed to Access VLAN 2 , VLAN 4
ip access-list extended deny_VLAN
deny ip 192.168.5.0 0.255.255.255 192.168.3.0 0.0.0.255 ( this command will deny the Vlan 5( containing port2 from accessing VLAN 3)
permit ip any any ( rest all Vlans will be accessible )
int vlan 5
ip access-group deny_VLAN in ( calling the ACL on the interface )
Spooster IT Services Team
balaji.bandi
permit ip any any
interface vlan 2
BB
After another look -  are you looking port2 (or is this read as vlan 2 ?)
BB
port2 must first assign to VLAN and then you use ACL under VLAN direction IN to filter which VLAN can access and which can not.
  int f0/2
int vlan 5
