boot from usbflash on rommon mode cisco 9300 switch
osman.elhanafy
Dears,
could anyone has a command reference for C9300 switch to boot an image from usbflash through rommon mode??
thanks
5 Replies 5
Leo Laohoo
Try this:  Emergency Recovery
it's good solution but i have ios on the flash but the switch can't boot from it
switch: dir bootflash:
Size Attributes Name
2097152 -rw- nvram_config
2097152 -rw- nvram_config_bkup
25711560 -rw- cat9k-cc_srdriver.16.08.01a.SPA.pkg
78484420 -rw- cat9k-espbase.16.08.01a.SPA.pkg
1598408 -rw- cat9k-guestshell.16.08.01a.SPA.pkg
404104132 -rw- cat9k-rpbase.16.08.01a.SPA.pkg
27681732 -rw- cat9k-sipbase.16.08.01a.SPA.pkg
52220868 -rw- cat9k-sipspa.16.08.01a.SPA.pkg
31130564 -rw- cat9k-srdriver.16.08.01a.SPA.pkg
14783424 -rw- cat9k-webui.16.08.01a.SPA.pkg
9152 -rw- cat9k-wlc.16.08.01a.SPA.pkg
6701 -rw- packages.conf
31663077 -rw- cat9k-rpboot.16.08.01a.SPA.pkg
4096 drw- .installer
185 -rw- bootloader_evt_handle.log
4096 drw- core
4096 drw- .prst_sync
4096 drw- .rollback_timer
4096 drw- gs_script
4096 drw- tech_support
4096 drw- dc_profile_dir
252 -rw- boothelper.log
118711 -rw- memleak.tcl
390 -rw- tam_client_app.log
4096 drw- .dbpersist
0 -rw- NVRAM
4096 drw- onep
35 -rw- pnp-tech-time
50710 -rw- pnp-tech-discovery-summary
616 -rw- vlan.dat
so what is the command should i wrote
BOOT ..........................??????.................
Osman,
If you just do "dir" at the rommon prompt, you should get a list of devices, one of which should be the USB. Once you get that you just boot from that as you would bootflash.
Cheers,
Scott
Command: boot packages.conf
NOTE: OMG. You're using 16.8.1a. I'd recommend you try a different version.
Jwaas9876
Hi Osman, I had a similar problem with a C9500-40X switch that was stuck in a boot loop.  Here is how I solved my issue:
1. Formatted an unused USB 16GB thumb drive with FAT32, downloaded the latest IOS-XE image file from cisco.com (cat9k_iosxe.17.06.04.SPA.bin), copied the file to the USB drive and inserted the USB drive into the standard USB slot on the front of the switch.
2. Power cycled the switch and pressed the mode button repeatedly during boot up to get into ROMMON mode
3. Entered this command from the switch: prompt to boot from the USB drive: boot usbflash0:/cat9k_iosxe.17.06.04.SPA.bin, the switch booted to the USB drive/.bin file and I was able to login.
