booting from rommon
kjohansen123
If I have 2 versions of ios on flash and I type boot from rommon without specifing which version to boot, which version will boot first?
Furose M
Level 3
Level 3
it will obey the config register. if config register is set to boot the first available IOS image, it will boot it. if it is set to boot based on the boot variable, it will boot that image specified in the boot variable.
Thanks. That helped alot. I deleted the old ios and rebooted the switch on the new ios. When I do a show ver isee that ROM still has the old version in it. How do I get it to reflect the correct version.
Switch1#show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 15.0(2)SG10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 07-Apr-15 09:46 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x123AE824
ROM: 12.2(31r)SGA4
ROM is bootrom which is different than the IOS image. you need not worry about ROM.
