Generating traffic on switches
afsharki2
hello friends,
I have a little lab finally setup, and I was wondering, what is a good way to generate traffic?  do i use software? or is there a way to do this via the switches?  I have setup a 2960x, 3850, 4510 R+E, 3750 and 2960s.  I'm doing it for the purpose of testing commands on Cisco such as QOS and flowcontrol.
Does anyone have any advice for generating heavy traffic?   A free solution would be nice, since I don't have money.
Thank you in advance
Reza Sharifi
You can use iperf. Its free and you can generate traffic with it using your laptop or desktop.
Here is the link to it.
https://onl.wustl.edu/NPR_Tutorial/Filters,_Queues_and_Bandwidth/Generating_Traffic_With_Iperf.html
Reza Sharifi
