Nexus SPAN
jearyro
Community Member
please help me on this error
error:-eth0/3 interface is a destination in another session
Jitendra Kumar
check below things,
Characteristics of Destination Ports
SPAN destination ports have the following characteristics:
  • A port configured as a destination port cannot also be configured as a source port.
  • A destination port can be configured in only one SPAN session at a time.
  • Destination ports do not participate in any spanning tree instance. SPAN output includes bridge protocol data unit (BPDU) Spanning Tree Protocol hello packets.
As per your log, you already have this port in another span session:
this is already discussed for N-9000 if you have same modal switch then can be refere
https://community.cisco.com/t5/switching/nexus-9000-span-destination/m-p/4618519#M524571
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_...
Jitendra
Jitendra
8 Replies 8
Jon Marshall
What command are you trying to enter that gives that message ?
What does a "sh monitor" look like ?
Jon
Jitendra Kumar
check below things,
Jitendra
Jitendra
Yes using N-9000 S thanks for the help.
Always welcome Dear 🙂
Jitendra
Jitendra
balaji.bandi
For me Looks like you have another Monitor session already running with that interface ? (Please confirm is that case with you)
Not sure what is the device and nexus code running : check limitation here :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide/sm_14span.html#concept_C6A5015041C642689D50237CE9F5F0E0
BB
yes already running with another..
You can not have more than 1, so you need to select another interface as destination, as per the guidelines and document.
BB
Georg Pauwen
if eth0/3 is not configured as a destination in another session, shut/no shut the interface. That might clear the interface.
If possible, post the full running configuration of the Nexus...
