Branch VPLS questions
stharmal
Hi All,
Our company uses VPLS and on one of the branch sites we have the following connections
VPLS ----PE ----NTU --- ASR 1002 Router ---Switch
I am bit confused about this config. Can some one help me what these configurations ? and is it correct way of doing for VPLS ?
On the ASR 1002 router I have the following config
interface GigabitEthernet0/0/1
 description  VPLS Connection
 bandwidth 200000
 ip address x.x.x.x
 no ip redirects
 no ip proxy-arp
 ip flow ingress
 load-interval 30
 speed 1000
 no negotiation auto
 cdp enable
 service-policy output qos-policy
interface GigabitEthernet0/0/2
 description switch port
 ip address x.x.x.x
 ip nbar protocol-discovery
 ip flow ingress
 ip pim sparse-dense-mode
 ip ospf authentication-key 7 xxxx
 negotiation auto
 cdp enable
 service-policy input class-mark
router eigrp 1
 network x.x.0.0
On the switch we have
interface GigabitEthernetx/y
 description ASr router
 ip address X.x.x.x
 ip ospf authentication-key xxx
 mls qos trust dscp
Hello.
As I understood you a customer 9not a provider), so you do not configure VPLS. If so, there is not reason to think of "VPLS configuration".
