Bridge VLANs
I have the need to translate VLAN Numbers between two areas of a customers network.  I have an MS250 in the middle. I have VLAN 8 coming in on a trunk port and I need to have it go out on a vlan trunk as VLAN 2352. what I thought I could do is have a port defined as Access VLAN 8 and have it looped to another port defined as Access VLAN 2352 and then away it would go on any Trunked interface that had VLAN2352 defined.
Is this possible
Did you do this same question here?
There is a feature for vlan translation but not for Meraki as far as I know
switchport vlan mapping 1649 755
https://community.cisco.com/t5/switching/meraki-switch-configuration-question/td-p/5209053
Joseph W. Doherty
I'm unfamiliar with the Meraki devices, but on a Cisco Catalyst switch, you can bridge two VLAN using access ports, as you propose.  (On a Catalyst, CDP will complain about the ports being in different VLANs and PVST/MST might be problematic, if enabled.)
