Build 9300 stack
bruce.thornton
Level 2
Level 2
I want to build a 9300 stack. I currently have a single switch online with the following:
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Permanent network-essentials
dna-essentials Subscription dna-essentials
Switch Ports Model SW Version SW Image Mode
* 1 64 C9300-48U 16.8.1a CAT9K_IOSXE INSTALL.
I want to upgrade the above switch to match the code of the switch below and make them a stack:
network-essentials      SmartLicense                         network-essentials
none                            Subscription Smart License   none
* 1 64 C9300-48p 16.9.4 CAT9K_IOSXE INSTALL
My question is can I upgrade the switch at 16.8.1a to 16.9.4 and make them a stack?
balaji.bandi
yes you upgrade the switch from 16.8.X  to 16.9.4
that is one of the stacking requirement, all the models should support, and should be the same IOS Version.
here is stacking information :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html#:~:text=Cisco%20Catalyst%209300%20Series%20Switches%20with%20Cisco%20StackWise%20%C2%AE%2D480,solution%20with%20flexible%20uplink%20a....
BB
