C1000-48P-4G-L Vlan propagation
motiengineering
Does C1000-48P-4G-L switch support VLAN propagation (VTP in cisco). Please help I am new here.
Hello
 It does. Always check the Data sheet.
●      Cisco VLAN Trunking Protocol (VTP) supports dynamic VLANs and dynamic trunk configuration across all switches.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1000-series-switches/nb-06-cat1k-ser-switch-ds-cte-en.html
balaji.bandi
adding @Flavio Miranda
Look at the config guide : ( if you looking to use VTP, make sure you use VTP v3 where possible due to security reason)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/configuration_guides/vlan/b_1527e_vlan_c1000_cg/configuring_vlan.html
if you already have VTP Server in the network, before you bring new VTP device to configure as Client before adding into the network. to minimize the risk.
BB
