C1000 switch missing object-group command
paul-d
Does the C1000 Specifically (C1000-48P-4G-L) not support object-groups?
I can see the ability to use an object-group's in an ACL however I cant find where to actually create the initial group.
Switch(config)#ip access-list extended TEST123
Switch(config-ext-nacl)#permit ip ?
A.B.C.D Source address
any Any source host
host A single source host
object-group Source network object group
switch(config)#obje?
% Unrecognized command
switch(config)#ip obj?
DanielP211
Hello!
The C1000 uses IOS and not IOS-XE, on which the feature is not supported.
BR
****Kindly rate all useful posts*****
balaji.bandi
what License you have ?
BB
The C1000 do not need any licence...
apologies - may have read that wrong Cat model. Cat 1K simple Lower end switch
personally do not belive that have feature you looking : check the config guide :
https://www.cisco.com/c/en/us/support/switches/catalyst-1000-series-switches/products-installation-and-configuration-guides-list.html
BB
