C1300 Catalyst not! How to set encapsulation for trunk
fabios
Level 3
Level 3
Dear All,
I bought 2 Cisco C1300-8MGP-2x for my home network since I have plurigigabit optical connectivity to the Internet.
I was kind of expecting to find the usual Catalyst os and command. Cisco made a very bad (in my view) choice to keep teh catalyst name in a non catalyst switch (rant off). So now in the deployment phase I discover there is no VTP support (fine is transparent the Catalyst3560 will communicate and I will configure manually).
But now I cannot find how to tell the switch to encapsulate the trunk link in DOT1Q. Docs Say nothing. The forum shows nothing.
Does anyone knows if there is a way? Or dot1q is the only encapsulated available and so there is no need to configure it?
Fabio
Or dot1q is the only encapsulated available and so there is no need to configure it? Correct not need anymore
MHM
MHM
KJK99
Level 3
Level 3
Ethertype Tagging
Select an Ethertype tagging method for the S-VLAN tag.
  • Dot1q-8100
  • Dot1ad-88a8
  • 9100 (old non-standard QinQ ethertype)
  • 9200 (non-standard QinQ ethertype)
Dot1q is the default.
Kris K
