C2948G
cjcisco2010
Community Member
I need help with configuring a Catalyst 2948G.  I have a serial cable with it.  i dont know how to configure/use it.  i am struggling for over a week with it.
when i turn it on, the led lits green.
appreciate any help.
7 Replies 7
Leo Laohoo
I am newbie to switches.  Please excuse my questions.
how do i know if my switch is l2 or l3
I was finally able to open terminal cli and access the switch.  but it is asking for tacacc password which i do not know.
how do i reset password.  i tried http://www.cisco.com/en/US/products/hw/switches/ps708/products_password_recovery09186a00801349aa.shtml but could not succeed.
booting image on my switch is bootflash:"cat4000-k8.8-4-7-GLX.bin".  may be, that will shed some light.
The Catalyst 2948G is a Layer 2 switch that operates in Catalyst OS or CatOS.
Hello Bislinks,
you probably have a CatOS box
post
sh ver
Hope to help
Giuseppe
sh ver
WS-C2948 Software, Version NmpSW: 8.4(7)GLX
Copyright (c) 1995-2005 by Cisco Systems, Inc.
NMP S/W compiled on May  9 2005, 18:26:07
GSP S/W compiled on May 09 2005, 17:31:33
System Bootstrap Version: 5.4(1)
Hardware Version: 2.3  Model: WS-C2948  Serial #: JAB050407G0
Mod Port Model              Serial #              Versions
1   0    WS-X2948           JAB050407G0          Hw : 2.3
                                                 Gsp: 8.4(7.0)
                                                 Nmp: 8.4(7)GLX
2   50   WS-C2948G          JAB050407G0          Hw : 2.3
       DRAM                    FLASH                   NVRAM
Module Total   Used    Free    Total   Used    Free    Total Used  Free
1       65536K  36560K  28976K  12288K   5717K   6571K  480K  315K  165K
Uptime is 0 day, 0 hour, 0 minute
glen.grant
   It's pretty easy to break into those .  When you boot the switch as soon as it asks for  password  quickly hit the enter key .  This should get you into the first level , quickly type enable and hit the enter key a couple times and you are in .  To clear the config use "clear config all "    .
i have been trying to do it, but failed a great number of times.
it goes into router> after i type enable and set password, it again asks for old password.
well, will try again may be untill i get into it.
IS reset ANOTHER OPTION?
