C2960X : No space left on device on upgrade
lucnovales29639
Trying to upgrade WS-C2960X-24TS-LL with c2960x-universalk9-tar.152-7.E4.tar image, I have "No space left on device" error during download-sw image.
Flash size is
Directory of flash:/
    2  -rwx        6968   Aug 2 2021 16:05:59 +00:00  private-config.text
    3  -rwx          34  Jul 15 2020 16:06:32 +00:00  pnp-tech-time
    4  -rwx       45684  Jul 15 2020 16:06:34 +00:00  pnp-tech-discovery-summary
    5  -rwx         616   Aug 2 2021 16:24:27 +00:00  vlan.dat
    6  drwx         512   Aug 2 2021 16:15:21 +00:00  c2960x-universalk9-mz.152-7.E3
  497  -rwx        3947   Aug 2 2021 16:05:59 +00:00  config.text
  498  drwx         512   Aug 2 2021 16:15:21 +00:00  dc_profile_dir
  500  -rwx        2072   Aug 2 2021 16:24:33 +00:00  multiple-fs
  501  drwx         512   Aug 3 2021 08:57:18 +00:00  uploadFile
56125440 bytes total (14224384 bytes free)
uploadFile is empty.
c2960x-universalk9-mz.152-7.E3.bin is 26Mo and html directory is 15Mo.
It remains only 14 Mo and 15.2-7.E4 tar file is 41 Mo.
Howto upgrade ?
Is there any update in documentation for a workarround ?
56Mo for flash is low, is there any command to extend flash: file system ?
Thx,
Luc.
balaji.bandi
you need to use below command :
archive download-sw /overwrite /reload tftp:[[//location]/directory]/image-name.tar privileged EXEC command.
BB
6 Replies 6
balaji.bandi
BB
lucnovales29639
I was not sure than process was complete. It seems OK.
Now I have same problem than c2960XR after upgrade.
Thanks.
Luc.
just to clarify is this upgrade due to Web GUI issue ?  - i will visit other post you mentioned later.
BB
No. Web issue is due to upgrade.
To clarify, I summarize the process :
  1. I upgraded this device from CLI with "archive download-sw /reload /overwrite tftp....",  and I didn't see the end of process,
  2. Then, it was an issue on the WEB manager,
  3. I tried to untar locally html directory using "archive download-file..." + "archive tar /xtract....".
    It was "no space left on device" with only a part of tar file (15Mo) in uploadFile directory.
Diagnostic error with "archive download-sw" command which download tar file twice and doesn't use flash: to store it during upgrade.
Leo Laohoo
This sub-directory looks odd.
due to precedent "archive download-file..." command.
