C3560E & 'IP Routing'
zak.humphries
Can anyone please assist with an issue I am having with a c3560E
I am trying to enable layer 3 routing on this switch, but the IP routing command is unavailable e.g 'IP ?' doesn't list it. I'm using the "c3560e-universalk9-mz.122-55.SE1.bin" image and according to the Cisco Feature Navigator IP routing is available on this model. Can anyone point in the right direction for what im doing wrong???
Cheers
Zak
15 Replies 15
Rags2
Hello I have a similar problem but unable to reslove
I am using an IE-2000-8T67P-G-E (PowerPC405) switch in a ring structure, when i input ip routing command on 1 switch it gives me below error but i see the same command active in another switch at the same time in the same ring structure.Why this command works on 1 switch and not on another , though the type of switch is the same.
Index 1 Feature: lanbase
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
License Count: Non-Counted
Index 2 Feature: lanlite
Period left: 0 minute 0 second
Index 3 Feature: enhancedlanbase
Period left: 8 weeks 4 days
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 4 Feature: iplite
Index 5 Feature: mrp-manager
License Count: 1/0/0 (Active/In-use/Violation)
Index 6 Feature: mrp-client
