C3560G and C2960's intervlan routing issue
Greg Wrobel
After upgrading all 2960 switches and 3560 (inter-vlan routing) to latest software version I more problems than I was hopping to fix. It appears that after upgrading configuration was changed on the switches. I manged to clean up most of it. One think left is that I cannot ping one of the VLAN interfaces on the 3560 from any 2960.
3560
interface Vlan2
 ip address 192.168.8.2 255.255.255.0
interface Vlan3
 ip address 192.168.7.1 255.255.255.0
interface Vlan4
 ip address 192.168.6.1 255.255.255.0
interface Vlan10
 ip address 10.1.1.1 255.255.255.224
The 2960 switches have IP addresses on VLAN 10 which is also Native VLAN. So, when I'm logged into 2960 switches and try to ping the VLAN 2 interface or anything on that VLAN I get nothing. It will ping fine to any other VLAN.
Why would that happen?
Thanks!
11 Replies 11
Martin Carr
Level 4
Level 4
Is the SVI up?
Martin
yes it is. Looks like only one switch now will ping from vlan 10 to 2
chsarkar
Hi Greg,
Do you have L2 Vlan-2 configured in 2960s ?
Regards, Chandan
I do. Here is config from 3560 and 2960. Some settings are not shown. Also last night when everybody left I found that all the switches started working fine. I makes me fell that someone is screwing with network.
Config from one 2960:
version 15.0
no service pad
service password-encryption
service sequence-numbers
hostname ASW01
mls qos map cos-dscp 0 8 16 24 32 40 46 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
vlan internal allocation policy ascending
vlan 2
 name Data
vlan 3
 name VoIP
vlan 4
 name Test
vlan 10
 name
interface FastEthernet0/1
 description 1A
 switchport access vlan 2
 switchport mode access
interface FastEthernet0/2
 description 1C
 switchport access vlan 4
interface FastEthernet0/3
 description 9A
interface FastEthernet0/4
 description 9C
interface FastEthernet0/5
 description 10A
interface FastEthernet0/6
 description 10C
interface FastEthernet0/7
 description 3A
interface FastEthernet0/8
 description 3C
interface FastEthernet0/9
 description 11A
interface FastEthernet0/10
 description 11C
interface FastEthernet0/11
interface FastEthernet0/12
 description 19C
interface FastEthernet0/13
 description 5A
interface FastEthernet0/14
 description 5C
interface FastEthernet0/15
 description 13A
interface FastEthernet0/16
 description 13C
interface FastEthernet0/17
 description 21A
interface FastEthernet0/18
 description 21C
interface FastEthernet0/19
 description 7A
interface FastEthernet0/20
 description 7C
interface FastEthernet0/21
 description 15A
interface FastEthernet0/22
 description 15C
interface FastEthernet0/23
interface FastEthernet0/24
 description Basement PC
interface GigabitEthernet0/1
 description c3560G-46
 switchport trunk native vlan 10
 switchport mode trunk
 srr-queue bandwidth share 10 10 60 20
 queue-set 2
 priority-queue out
 mls qos trust dscp
 macro description cisco-switch | cisco-switch
 auto qos voip trust
 spanning-tree link-type point-to-point
interface GigabitEthernet0/2
 mls qos trust dscp
interface Vlan1
 no ip address
 no ip route-cache
interface Vlan2
 no ip address
 no ip route-cache
interface Vlan3
 no ip address
 no ip route-cache
interface Vlan10
 ip address 10.1.1.2 255.255.255.224
Config from 3560
version 15.0
no service pad
service timestamps debug uptime
service timestamps log datetime
hostname CSW
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
system mtu routing 1500
vtp domain
vtp mode transparent
udld aggressive
ip routing
no ip cef optimize neighbor resolution
no ip domain-lookup
ip domain-name
ip dhcp excluded-address 192.168.6.1 192.168.6.10
ip dhcp excluded-address 192.168.6.150 192.168.6.254
ip dhcp excluded-address 192.168.9.1 192.168.9.10
ip dhcp pool test
 network 192.168.6.0 255.255.255.0
 domain-name
 default-router 192.168.6.1
 dns-server 192.168.8.20 192.168.8.23
 netbios-name-server 192.168.8.20
ip dhcp pool Wi-Fi
 network 192.168.9.0 255.255.255.128
 default-router 192.168.9.1
 domain-name compuweigh.local
ip dhcp pool Guest
 network 192.168.99.0 255.255.255.224
 dns-server 8.8.8.8 8.8.4.4
 default-router 192.168.99.1
 lease 0 1
mls qos
errdisable recovery cause link-flap
errdisable recovery interval 60
spanning-tree loopguard default
spanning-tree vlan 1-4094 priority 24576
vlan 2
 name Data
vlan 3
 name VoIP
vlan 4
 name Test
vlan 5
vlan 6
vlan 9
vlan 10
vlan 11
vlan 99
ip ssh version 2
macro global description cisco-global | cisco-global
interface Port-channel1
 switchport nonegotiate
 speed 100
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
 switchport access vlan 3
 switchport voice vlan 3
 switchport priority extend trust
 mls qos trust cos
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 channel-group 1 mode active
interface GigabitEthernet0/10
interface GigabitEthernet0/11
 ip access-group Consultants in
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
 mls qos trust cos
 spanning-tree portfast trunk
interface GigabitEthernet0/15
interface GigabitEthernet0/16
 switchport trunk allowed vlan 2-6,9,10
interface GigabitEthernet0/17
 switchport trunk native vlan 2
 switchport trunk allowed vlan 2-6,10
interface GigabitEthernet0/18
 switchport trunk native vlan 6
interface GigabitEthernet0/19
 switchport trunk allowed vlan 2,4
interface GigabitEthernet0/20
 switchport trunk allowed vlan 2,4,99
interface GigabitEthernet0/21
 description Hyper-V2
interface GigabitEthernet0/22
interface GigabitEthernet0/23
 switchport access vlan 11
 switchport trunk allowed vlan 2,11
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
 switchport trunk allowed vlan 2,4,9,99
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
 srr-queue bandwidth shape 10 0 0 0
 queue-set 2
 auto qos voip trust
 macro description cisco-switch | cisco-switch | cisco-switch
interface GigabitEthernet0/46
 queue-set 2
 mls qos trust dscp
 auto qos voip trust
interface GigabitEthernet0/47
 queue-set 2
 mls qos trust dscp
 auto qos voip trust
interface GigabitEthernet0/48
 queue-set 2
 mls qos trust dscp
 auto qos voip trust
interface GigabitEthernet0/49
 queue-set 2
 mls qos trust dscp
 auto qos voip trust
interface GigabitEthernet0/50
 queue-set 2
 mls qos trust dscp
 auto qos voip trust
interface GigabitEthernet0/51
 queue-set 2
 mls qos trust dscp
 auto qos voip trust
interface GigabitEthernet0/52
 queue-set 2
 mls qos trust dscp
 auto qos voip trust
interface Vlan1
 no ip address
interface Vlan2
interface Vlan3
interface Vlan4
interface Vlan5
interface Vlan6
interface Vlan9
 ip address 192.168.9.1 255.255.255.128
interface Vlan10
interface Vlan11
 ip access-group ConsultantsVLAN in
interface Vlan99
 ip address 192.168.99.1 255.255.255.224
 ip access-group Guest in
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.8.1
Hey Greg - So now you mean you are able to ping to all Vlan 2 IPs  ?
Sounds interesting.. If so, did you see any change in config anywhere ?
Regards, Chandan
Its more interesting than that. Last night I downgraded c3560 to latest version of 12.2. This morning I was able to ping every switch only once. When I tried to ping it second time, I got request timed out. I check arp cache on all switches and it looked fine.
Hi Greg Wrobel,
You have to assign ip address for VLAN 1 of all available L3 & L2 switches..
and enable " ip routing " command on you L3 switch.
For example :
if using 192.168.1.0/24 range of ip for VLAN 1
Assign 192.168.1.1 for L3 switch
192.168.1.10 , 20, 30 , 40.. for L2 switches how you needed..
finally enable " ip routing " on your L3 switch..
coreswitch(config)#ip routing
Please Check and let me know..
Khaleelur Rahman
*Please dont forget to rate if this info is helpfull
I ip route been running for years.
CSW#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.8.1 to network 0.0.0.0
C    192.168.8.0/24 is directly connected, Vlan2
     192.168.9.0/25 is subnetted, 1 subnets
C       192.168.9.0 is directly connected, Vlan9
     192.168.99.0/27 is subnetted, 1 subnets
C       192.168.99.0 is directly connected, Vlan99
     10.0.0.0/27 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, Vlan10
C    192.168.6.0/24 is directly connected, Vlan4
C    192.168.7.0/24 is directly connected, Vlan3
S*   0.0.0.0/0 [1/0] via 192.168.8.1
you do not have any IP address assigned to vlan 2 on 2960 switch, what ip you are trying to ping from 3560 to 2960 ? moreover, your default route is pointing to 192.168.8.1, where is 192.168.8.1 configured ?
Raghavendra Bandaru
" Rate this, if it is helpful for you"
Greg Wrobel
So today I cleared config on 3560 and reloaded from file, same thing. everything works except communication between VLAN 2 and VLAN 10 where switches IP addresses are. All started after upgrading to c3560-ipbasek9-tar.150-2.se8. Occasionally I get ping replies for few minutes once I restart switches.
Greg Wrobel
It turned out that version 15 was the problem. Downgraded to version 12 and it works properly.
