C3650 how to configure interface vlan rate limit
h.dam
Hi ,
On switches C3650 (L3) whichi is ios-xe, I'd like to configure rate limit on interface vlan using QoS. Can someone give me some configuration examples?
My end devices are connected on L2 switch e.g. 2960. In this case, should I also configure Qos on the ports where devices connected?
Thanks.
2 Accepted Solutions
Something like this:
policy-map pm-police
class class-default
police cir 500000000
conform-action transmit
exceed-action drop
interface vlan xxx
service-policy output pm-police
service-policy input pm-police
Hello
You could also try:
class-map Policed_traffic
match input-inter xx xx ( trunk interfaces allowing the vlan)
policy-map Policed_traffic_pm
class  Policed_traffic
police 51200000 1600000 exceed-action drop
access-list 100 permit ip any any
class-map policed_vlan140_cm
match access-group 100
policy-map Policed_vlan140_pm
class policed_vlan140_cm
service_policy Policed_traffic_pm
int vlan 140
service-policy input Policed_vlan140_pm
int xx (all trunk links with vlan140 traversing)
mls qos vlan-based
res
Paul
Kind Regards
Paul
13 Replies 13
Philip D'Ath
If you want the QoS to be "per port" then you should apply it on the port level.  If you want it to apply to everything on the whole VLAN then apply it on the VLAN.
I need to apply on the whole vlan. Could you send me some configuration examples or show me a link ?
class class-default
exceed-action drop
interface vlan xxx
Hi Philip,
Thanks for this example.
I thought that service-policy output is enough. Whats your reason to apply both input & output?
Do you want the speed direction in one direction - or both directions?
I got it. Both directions are better. thanks again.
here's my output:
class-map match-any vlan-class
match vlan 140
match vlan 160
policy
-map pm-police
class vlan-class
exceed-action drop
class class-default
interface vlan 140
interface vlan 160
You have made it more complicated than it needs to be.  Get rid of "vlan-class", and change to the below.  You can apply the same policy to as many vlans as you want.  Some people like to name the policy after the speed to make it quick and easy to apply to new vlans/ports.
class class-default
exceed-action drop
class class-default
Hello
You could also try:
int vlan 140
mls qos vlan-based
res
Paul
Kind Regards
Paul
Thank you for this vlan-based qos example. I'll choose one which impacts less in my production network.
Hi Philip,
I've implemented as you said, but I got an error when I applied on interface vlan:
interface vlan 140
Only Marking policy action is supported on SVI interface. Policy Rejected
It is a cisco C3650-24TS, v16.3.1
Did you have this issue?
What happens if you put it on an actual port, rather than on a VLAN interface?
It works if I put it on interface (trunk) of this 3650 L3 switch, which is distribution layer.
Now, I'm working on access layer switches. They are 2960x v15.2 ios. I got an error when I put the policy on access port:
%QoS-install-failed error
I'm confused that Qos command behavior changes if switches are of different type.
Still searching a workaround...
h.dam
Hi Philip,
