c3750-ipbaselmk9 and basic static routing .?
j-tagesson
Community Member
Hi there.
When I'm going to upgrade my 3750G stack the download page states that I should use the
ipbaselmk9 version of ios.
Does it support basic routing features ?
It is meant only for reducing the size of the image and not the feature
Hope this answers your question.
Cheers
Somu
Rate helpful posts
6 Replies 6
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
If I recall correctly, should support static routing, RIP and EIGRP stub routing.
SunilKhanna
Level 5
Level 5
An IP Base IOS
set includes  advanced quality of service (QoS), rate limiting, access control lists  (ACLs), and basic static and Routing Information Protocol (RIP)  functions. Dynamic IP routing protocols (Open Shortest Path First  (OSPF), BGPv4, Enhanced Interior Gateway Routing Protocol (EIGRP)) are  available only on the IP services image.
Please have a look at the URL
What is the difference between an IP base image and an IP services image
Sunil
If you think the post was helpful, please do not forget to rate the content!!!
Regards, Sunil Khanna
Hi guys, thnx for your awnser. I know this is the case for the regular ipbase versions, I just want to know if the lm in the version (less memory I suppose) disables some ipbase features or if it's the same as a std ipbase.
Cheers
Somu
Rate helpful posts
Thank you.
BTW can i mix ipbaselmk9 3750:s with ipbasek9 350X switches in the same stack ?
Use the same exact image for the entire stack.
