Nexus 7000 vpc peer-gateway
timcalkins
We have run into an issue between a couple of N7Ks in a vPC topology. We have the N7Ks set up with the "vpc peer-gateway" and we have several SVI's between them running HSRP. The issue is that we have a situation in which 4 of the SVIs on the one N7K B switch (vpc secondary) the N7K is not longer acting as a gateway, only the A switch is the active gateway. All of the other SVIs are able to still use both N7Ks as a gateway.
Here is the output that has me concerned:
On the A Switch:
G 2201     0026.9802.20c1    static       -       F    F  sup-eth1(R)
G 2202     0026.9802.20c1    static       -       F    F  sup-eth1(R)
G 931      0026.9802.20c1    static       -       F    F  sup-eth1(R)
G 2211     0026.9802.20c1    static       -       F    F  sup-eth1(R)
G 932      0026.9802.20c1    static       -       F    F  sup-eth1(R)
on the B switch:
* 2201     0026.9802.20c1    static       -       F    F  vPC Peer-Link
* 2202     0026.9802.20c1    static       -       F    F  vPC Peer-Link
* 931      0026.9802.20c1    static       -       F    F  vPC Peer-Link
G 2211     0026.9802.20c1    static       -       F    F  vPC Peer-Link(R)
* 932      0026.9802.20c1    static       -       F    F  vPC Peer-Link
For those 4 vlans the B switch is not acting as a gateway.
Has anyone had this experience, I am tempted to do a "shut" and "no shut" to bounce the SVI and see if it starts forwarding again.
I am hesitant as I am not sure if this will fix the gateway issue and do not want to introduce any other problems.
Any ideas?
Jerry Ye
What NXOS version are you running?
jerry
we are using 4.2(3)
I believe you are hitting this bug:
CSCtf91507
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtf91507
the fix is intergrated in 4.2.6 or above. I would suggested you to upgrade the N7Ks to 4.2.6 or 4.2.8.
HTH,
jerry
excellent, thanks.
Found also that shutting the SVI forced the peer switch to become the gateway, then "no shut" to the primary switch and both are acting as gateway again.
