C3750X power stack
orielrose2011
Community Member
Hi Guys
I am trying to build a C3750X power stack however just come to know that only 4 switches can be power stacked in ring topology.
I have 6 switches in stack is it possible to have two power stacks within the one stack of 6 switches ?
4 Accepted Solutions
rmcarthur
Level 7
Level 7
Hi Oriel, yes, you can either use the expandable power system to make a single power stack of 6 or have 2 power stacks of 3 within a single data stack.
From
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-578933_ps10744_Products_Q_and_A_Item.html
Q. How many Cisco StackPower stacks can be built within one data stack?
A. ...... Another option is to build 3 Cisco Stackpower stacks of three each.
Hi Oriel, your stack ports are currently shut, you will need to enable them to bring the powerstack up.
Issue the following command from SW1# prompt "stack-power switch port 1 enable" where is the switch number.
Hi Oriel, issue the command from the priv exec, not config mode.
SW1#stack-power switch 1 port 1 enable
not SW1(config)#
Hi Oriel, glad to hear it's now working for you.
I think that you will have to do the math to work out if your power is under-budget (add the switch power budgets and substract from available PSUs), in practice you would see a console message warning that you were below budget.
Here is a useful link for understanding and calculating power budgets.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10745/white_paper_c11-663717.html
Please rate helpful posts and mark them as answered to help others find a solution to similar problems.
Thanks and good luck!
10 Replies 10
rmcarthur
Level 7
Level 7
From
okay
i cant see the neighbors with this configuration
stack-power stack power1
stack-power stack mypower
stack-power stack mypower1
stack mypower
stack-power switch 2
stack mypower
stack-power switch 3
stack mypower
stack-power switch 4
stack mypower1
stack-power switch 5
stack mypower1
stack-power switch 6
stack mypower1
SW1#sh stack-power
Power stack name: mypower-1
    Stack mode: Power sharing strict
    Stack topology: Standalone
    Switch 1:
        Power budget: 1663
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Port 1 status: Shut
        Port 2 status: Shut
        Neighbor on port 1: 0000.0000.0000
        Neighbor on port 2: 0000.0000.0000
Power stack name: mypower1
    Switch 6:
        Power budget: 1663
        Port 1 status: Shut
        Port 2 status: Shut
Power stack name: mypower1-4
    Switch 4:
        Power budget: 1663
        Port 1 status: Shut
        Port 2 status: Shut
Power stack name: mypower1-5
    Switch 5:
        Power budget: 1663
        Port 1 status: Shut
        Port 2 status: Shut
    Switch 2:
        Power budget: 1663
        Port 1 status: Shut
        Port 2 status: Shut
why its showing
     Port 1 status: Shut
        Port 2 status: Shut
How i can no shut those ports ?
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 15.0(1)SE, RELE
ASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 20-Jul-11 09:09 by prod_rel_team
SW1(config)#stack-power switch 4 ?
SW1(config-switch-stackpower)#?
Switch stack power configuration mode:
  default         Set a command to its defaults
  exit            Exit from switch stack power configuration
  no              Negate a command or set its defaults
  power-priority  Switch's port priority
  stack           Switch's power stack
  standalone      Configure switch to not participate in power stack
i cant see this command...
not SW1(config)#
Yes it worked
thanks
let me see the result and will update you shortly
Thats great you are an absolute star.
Just one more question please, how i can find out if my system is running in ngative budget. Right now i have got power-stack of 3 switches and only 1 power supply is connected...
    Stack topology: Ring
    Switch 6:
        Power budget: 343
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1:
        Neighbor on port 2:
    Switch 5:
        Power budget: 373
        Low port priority value: 20
        High port priority value: 11
        Switch priority value: 2
        Neighbor on port 1:
        Neighbor on port 2:
    Switch 4:
        Power budget: 343
        Neighbor on port 1:
        Neighbor on port 2:
SW1#show env power all
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-1100WAC    LIT12120W14 OK              Good     Good     1100/0
1B  C3KX-PWR-1100WAC    LIT13509648 OK              Good     Good     1100/0
2A  C3KX-PWR-1100WAC    LIT16511011 OK              Good     Good     1100/0
2B  C3KX-PWR-1100WAC    LIT145015KA OK              Good     Good     1100/0
4A  C3KX-PWR-1100WAC    LIT12280KGL OK              Good     Good     1100/0
4B  C3KX-PWR-1100WAC    LIT14232163R No Input Power  Bad      N/A      1100/0
5A  C3KX-PWR-1100WAC    LIT144232KUF No Input Power  Bad      N/A      1100/0
5B  C3KX-PWR-1100WAC    LIT14511142P No Input Power  Bad      N/A      1100/0
6A  C3KX-PWR-1100WAC    LIT14523125Q No Input Power  Bad      N/A      1100/0
6B  C3KX-PWR-1100WAC    LIT14481231T  No Input Power  Bad      N/A      1100/0
Thanks a lottttttttt for all your helo
