C3850 24XS fan module
RR57871
We would like to change the airflow direction (and thus the fan module) on a CISCO C3850-24-XS-S switch.
Is it possible on this type of switch ? We have also seen that the CISCO C3850-48-XS-S had two fan modules (FAN-T3-R= & FAN-T3-F=). Are those modules compatible with the 24-XS ?
Thank you,
HI,
Yes it is compatible with all 3850 Models.
Refer below datasheet.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
Mark my post
RR57871
Hello
So we ordered the FAN-T3-R= and we tried to plug it into our CISCO C3850-24-XS-S and... it didn't fit at all.
First, the module T3 is twice the length and it wasn't held very well in the module slot.
Second, the electrical plug has a misplug-proof socket that prevents the T3 to be electrically connected.
Conclusion : the FAN-T3-R= module is not compatible with the CISCO C3850-24-XS-S.
Are there any other parts that could be compatible ?  We won't test any home-made solution because we do not want to loose the CISCO warranty.
Thank you,
