01-16-2023
01:14 AM
- last edited on
01-16-2023
01:39 AM
by
Yanli Sun
The switch automatically restarted last night, and the cause of the problem has not been found after searching the Internet for a long time. Can anyone please tell me how to solve this problem. After restarting, the error message is as follows, and the detailed log information is in the attachment.
SW24 uptime is 11 hours, 36 minutes
Uptime for this control processor is 11 hours, 38 minutes
System returned to ROM by Critical process platform_mgr fault on rp_0_0(rc=136)
System restarted at 22:55:07 Khmer Wed Jan 11 2023
System image file is "flash:/cat3k_caa-universalk9.16.12.03a.SPA.bin"
Last reload reason: Critical process platform_mgr fault on rp_0_0(rc=136)
01-16-2023 01:40 AM
Last reload reason: Critical process platform_mgr fault on rp_0_0(rc=136)i
ts bug upgrade to suggested version to fix the issue :
https://bst.cisco.com/bugsearch/bug/CSCvr58845
01-16-2023 02:06 AM
Post the complete output to the following commands
I suspect the crash is due to FN - 72323 - Cisco IOS XE Software: QuoVadis Root CA 2 Decommission Might Affect Smart Licensing, Smart Call Home, and Other Functionality.
01-16-2023 03:01 AM
The following is the information output from the two commands you provided Please help me further analyze the problem, if you can
I've looked at your reply, which looks like a problem with the system version, and I haven't had time to update it.
I think I can update my credentials to try and fix the problem.
Thank you for your help
SW249#show log on switch 1 up det
UPTIME SUMMARY INFORMATION
First customer power on : 06/28/2018 14:04:47
Total uptime : 2 years 25 weeks 4 days 16 hours 18 minutes
Total downtime : 2 years 3 weeks 2 days 3 hours 37 minutes
Number of resets : 10
Number of slot changes : 1
Current reset reason : Critical process platform_mgr fau
Current reset timestamp : 01/11/2023 15:55:05
Current slot : 1
Chassis type : 0
Current uptime : 0 years 0 weeks 4 days 18 hours 5 minutes
UPTIME CONTINUOUS INFORMATION
Time Stamp | Reset | Uptime
MM/DD/YYYY HH:MM:SS | Reason | years weeks days hours minutes
06/28/2018 14:04:47 Reload 0 0 0 0 0
06/28/2018 14:12:00 Reload 0 0 0 0 0
06/28/2018 14:20:14 Reload 0 0 0 0 0
07/08/2020 14:00:18 Power Failure or Unknown 0 0 0 17 50
07/09/2020 14:05:51 Power Failure or Unknown 0 0 0 0 5
07/09/2020 14:13:14 Reload Command 0 0 0 0 0
07/09/2020 14:21:03 Reload Command 0 0 0 0 0
07/09/2020 14:30:36 Reload Command 0 0 0 0 5
07/09/2020 15:00:50 Reload Command 0 0 0 0 5
07/21/2020 21:55:37 Power Failure or Unknown 0 0 0 10 5
01/11/2023 15:55:05 Critical process platform_mgr fau 2 24 5 16 2
SW249#show switch detail
Switch/Stack Mac Address : 6c6c.d3b9.9080 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 6c6c.d3b9.9080 1 V07 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 DOWN DOWN None None
01-16-2023 03:36 AM
2 years, 24 weeks uptime before the crash on 11 January 2023.
I am certain the crash is due to the expired Quo Vadis certificate.
Update the firmware to 16.12.8 or apply the workaround mentioned in the Field Notice.
