c3kx-nm-1g compatibility with 3850
PaulReveco
Frequent Visitor
Frequent Visitor
I want to replace a WS-C3750X-24S with a WS-C3850-24S-E, I would like to know if the same C3KX-NM-1G card can be used.
NAME: "Switch 1 - FRULink Slot 1 - FRULink Module", DESCR: "FRULink 1G Module"
PID: C3KX-NM-1G , VID: V01 , SN: FDO17322DX3
2 Accepted Solutions
inderdeeps
Level 9
Level 9
@PaulReveco : You can check the compatibility on below link
https://tmgmatrix.cisco.com/?npf=112
here is the modules supported by Cat 3850 : (make sure you use the correct IOS and upgrade to meet the requirement of Modules.
Network modules for the Cisco Catalyst 3850 Series
C3850-NM-4-1G=
4 x Gigabit Ethernet network module spare
C3850-NM-2-10G=
4 x Gigabit Ethernet/2 x 10 Gigabit Ethernet network module spare
C3850-NM-BLANK=
Network module blank spare
C3850-NM-4-10G=
4 x Gigabit Ethernet/4 x 10 Gigabit Ethernet network module spare
C3850-NM-8-10G=
8 x Gigabit Ethernet/8 x 10 Gigabit Ethernet network module spare
C3850-NM-2-40G=
2 x 40 Gigabit Ethernet network module spare
BB
inderdeeps
Level 9
Level 9
From what I see I would need another type of card, such as the C3850-NM-4-10G.
thanks for the matrix.
C3850-NM-4-1G=
C3850-NM-2-10G=
C3850-NM-BLANK=
C3850-NM-4-10G=
C3850-NM-8-10G=
C3850-NM-2-40G=
BB
Reconsider the choice of platform --3850 is already end-of-sale and last date for software is 30 October 2021.
