C4500 Sup Redundancy OS upgrade.
inb
Good morning.
I am trying to upgrade the C4500 engine redundant equipment to the OS.
Current version: 3.4.0SG
Current ROMMON: 15.0(1r)SG5
New version: 3.11.3aE
New ROMMON: 15.0(1r)SG10
// config
redundancy
mode sso
It is operating in SSO mode.
However, in order to go from 3.4.0 to 3.11.3, we need to upgrade ROMMON to 15.0(1r)SG10 first.
I have completed the procedure below using the guided documentation and the method seen by the community.
Please help me to make sure the procedure is correct.
-Active SUP(Slot 5)
1.no boot system flash bootflash:cat4500e-universalk9.SPA.03.04.00.SG.151-2.SG.bin
2.boot system flash bootflash:cat4500-e-ios-promupgrade-150-1r-SG10
3.boot system flash bootflash:cat4500e-universalk9.SPA.03.11.03a.E.152-7.E3a.bin
4.config-register 0x2102
5. write
6. show bootvar
7. redundancy force-switchover
7-1. Active SUP Upgrade....
7-2. Active SUP Upgrade Complete.
7-3. show redundancy (Booting and SSO check)
-Standby SUP(Slot 6)
8. no boot system flash slavebootflash:cat4500e-universalk9.SPA.03.04.00.SG.151-2.SG.bin
9.boot system flash slavebootflash:cat4500-e-ios-promupgrade-150-1r-SG10
10.boot system flash slavebootflash:cat4500e-universalk9.SPA.03.11.03a.E.152-7.E3a.bin
11.config-register 0x2102
12. write
13. show bootvar
14. redundancy force-switchover
14-1. Standby SUP Upgrade.
14-2. Standby SUP Upgrade Complete.
14-3. show redundancy (Booting and SSO check)
15. End.
16. As a result, Slot 5 operates as Act, Slot 6 Std.
There is a lot of downtime.
Is the procedure above correct?
and tesk 2.
1. no boot system flash bootflash:cat4500e-universalk9.SPA.03.04.00.SG.151-2.SG.bin
2. boot system flash bootflash:cat4500-e-ios-promupgrade-150-1r-SG10
3. boot system flash bootflash:cat4500e-universalk9.SPA.03.11.03a.E.152-7.E3a.bin
4. no boot system flash slavebootflash:cat4500e-universalk9.SPA.03.04.00.SG.151-2.SG.bin
5. boot system flash slavebootflash:cat4500-e-ios-promupgrade-150-1r-SG10
6. boot system flash slavebootflash:cat4500e-universalk9.SPA.03.11.03a.E.152-7.E3a.bin
7. config-register 0x2102
8. write
9. redundancy reload peer
9-1. Stadnby(slot6) SUP upgrade
9-2. Standby(slot6) SUP upgrade Complete
10. redundancy force-switchover
10-1. Active(slot5) SUP upgrade
10-2. Active(slot5) SUP upgrade Complete
11. redundancy force-switchover
12. end. Active(slot5), Standby(slot6)
Which procedure is correct?
Leo Laohoo
This is NOT necessary if the redundant supervisor card is in the same chassis as the primary supervisor card.
If that was me, I would just issue the "reload" command.
After the chassis has rebooted, I would remove this line.
Finally, why choose 15.0(1r)SG10?  This file was released back on 03 July 2014.
I would recommend going straight to 15.0(1r)SG16 instead.
8 Replies 8
Leo Laohoo
Thank you.
If so, will procedures 8~13 disappear?
Simply through redundancy force-switchover
Is the process complete by simply switching the engine?
The sup model is 7-e.
So I can't use that version.
I am going to proceed with the minimum ROMMON version in the guide.
As you said, in step 14 I will reboot the entire chassis via reload.
After reloading at number 14
Is the active engine slot 5?
Or is slot 6 active before reloading?
What's your opinion on tesk 2?
I think tesk 2 is cleaner.
But there is no way to verify it.
Leo Laohoo
For a simplified version, please read THIS.
Thank you.
Best wishes for a Happy New Year.
@inb wrote:
Thank you.
Thanks, you too!
Let us know how the upgrade went.
