cannot login to the wlan-ap0 wireless module in a 891 router
Stan Spice
I cannot login to the wlan-ap0 wireless module in a 891 router
I did service-module wlan-ap0 session used Cisco as username and password
But it didnt work.
Reset the module using the method below and tried the login again but no luck
service-module wlan-ap0 reset default-config
Any idea why? How can we do a password recovery
stan
sudkulka
There is no password recovery available on emebdded AP only a password reset. this is achieved by resetting Ap to factory default
Router# service-module wlan-ap0 reset default-config
- BUT before doign this, please try the below to see if you can login into AP
Router# service-module wlan-ap0 session
Username:
Enter Username and Password configured on router
If prompted again, enter Cisco/Cisco
NOTE: These steps need to be performed in above order.
Sudha Kulkarni
Wireless TAc
I figured out the issue
It looks like when you do a "service-module wlan-ap0 session" we have to provide the username password that was configured on router.
Once you do that you can use Cisco Cisco to login to the wireless module
Try:
service-module wlan-ap0 session clear
You may still have the last session open.
